what valve springs you guys recommend?
When boosted, you have to consider what the boost takes away from your spring pressure. If you have a 2" intake valve, it has a surface area of ~3 square inches. With 10 pounds of boost, that equates to a reduction in effective spring pressure by ~ 30lbs. Now factor in your RPM! I ran 918's on low boost. No way I would run 918's on anything making 10psi or more.
