master power turbos
Old Nov 22, 2008 | 09:30 AM
Reject's Avatar
Originally Posted by ModularTurbo
I have a crazy special on Borgs right now if anyone is interested.
my next build up i'm definitely going to hit yall up to get alot of my **** together at the same place. maybe i should step it up to a big B-dub
Old Nov 22, 2008 | 12:37 PM
67Firebird455's Avatar
He's got them, you know how to reach him! Check modularturbo.com from time to time, Rob will be updating the products section of the site soon!
Tony
Old Nov 22, 2008 | 07:51 PM
anarchy99's Avatar
Originally Posted by camarols1
It all depends on your power goals and packaging them on your car.
Some cars are easier to package small twins versus a big single.
Check the flow ratings/compressor maps of some turbos to guide your decision of single or twins, then call your favorite turbo vendor to fine tune the specifics.
Turbos are rated at how many lbs per minute of air they can flow at a given pressure ratio.
You can go a little bigger on an automatic track car.
As a general guide, 1 lb/min will support 10 HP
(ex. my twin 66mm Borgs are good for 80 lbs/min each, so they could support up to 1600HP).
That is beyond what HP I plan to make, but my HP goal of 1,100~ is right in the sweet spot of the compressor maps so they should be very efficient at my power level.
The twin 38mm gates are fine, that is what I am using.
that's weird. My twin turbonetics T-66's only support 72 lb's a minute. wonder why the difference.
Old Nov 22, 2008 | 11:31 PM
ModularTurbo's Avatar
Extended Tip technology AKA ETT comp wheel. The ETT wheels are stretched forward, it allows for more air flow in a given diameter, and more airflow at a slower turbine speed. Now if only you could get a ball bearing Airwerks now that would be the shizznit.
Old Nov 23, 2008 | 12:23 AM
anarchy99's Avatar
yeah, but aren't they like $1400.00 a piece.
Old Nov 23, 2008 | 01:25 PM
Rob @ Modular has the hook up on those things, give him a call. You'll be surprised what kind of deal he can get you on any size of those units!
Old Nov 23, 2008 | 01:47 PM
anarchy99's Avatar
thanks. Already own a set though. Talked to him before though. Nice guy for a coastie.
Old Nov 23, 2008 | 01:49 PM
That's bad *** though with twin 66's, those will make a ton of power!
Old Nov 23, 2008 | 08:33 PM
4SFEDZ's Avatar
shoot me a pm with some prices, maybe a nice 88mm!
Old Nov 23, 2008 | 11:18 PM
nice guy for a coastie. LOL
What the heck is that suppose to mean.
I'll have you know that us coasties are all nice guys.
Old Nov 24, 2008 | 06:23 PM
anarchy99's Avatar
