LSX or Iron Block
Old Nov 16, 2008 | 09:41 PM
js2fst's Avatar
Originally Posted by Sluggish
The LSx blocks take a ton of machine work. I hope your ready do drop about 30k+ so 2k more for a block isn't ****.
That is why I am selling my crank and pistons.
Old Nov 17, 2008 | 10:26 PM
10sec_rx7's Avatar
7 Second Club
Originally Posted by MY99TAWS6
So why again does a normal person need an lsx block unless they are looking for 7s or faster?
we are chasing 7's and will do it on a standard iron block... LSX is great if you want 440ci tho
Old Nov 17, 2008 | 10:40 PM
yelnatsch517's Avatar
So he could run it for 200k miles without replacing it.
Old Nov 19, 2008 | 05:59 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
Yeah... there sure ARE lots of people running in the 9's and a few in the 8's with 4-bolt standard LS blocks.... BUT!... how many of them were pushing water with the 4-bolt block and heads? I'd be willing to bet anything that 75% or more of them have continuous head gasket headaches. What is piece of mind and replacing head gaskets worth to you?
Old Nov 19, 2008 | 06:51 AM
Shawn @ VA Speed's Avatar
Fireball went a bunch of mid 8's with his stock ls2 block engine-hell its even stock displacement.no head gasket issues,he did blow a head gasket after putting the car in the 8.30 range but we are going to fix that issue over the winter-look for 7's on 4 bolt heads next year with no head gasket issues.Alot of the guys having head gasket problems is due to improper parts selection and or improper tuning.1 thing alot of people need to realize is too little timing is just as bad and too much timing on a f/i setup
Old Nov 19, 2008 | 07:10 AM
Fireball's Avatar
I haven't confirmed that I blew a headgasket yet. oil was clean so I'm kinda wondering if I heard an exhaust leak from a cracked header or something...
probably would've been damn close to 7s if I wasn't driving through the converter this year
I went high 8.30s without pushing a drop...only when I got greedy and added 1.5* of timing, did it push a few pints Nothing magical either...box-stock 4-bolt ETP 225 heads, regular ARP head studs (not that exotic L19 stuff), and GM 5-layer MLS gaskets
Old Nov 19, 2008 | 08:39 AM
cablebandit's Avatar
what timing were you at that was safe for your setup and what fuel? what plugs?
Old Nov 19, 2008 | 08:52 AM
Fireball's Avatar
More than 20*
C16
AR3911
Old Nov 19, 2008 | 08:57 AM
Big Mike's Avatar
Very impressed with your setup Brian!!!!!!
Old Nov 19, 2008 | 09:46 AM
427's Avatar
427
I went 7's on a 4 bolt a few times pushing a bit of water. It pushed almost two quarts when it went 6's.........
Kurt
Old Nov 19, 2008 | 09:54 AM
BLNLS1/RX7's Avatar
Originally Posted by Exotic Performance Plus
If you're looking for a nine second 1/4 mile car, the 6.0L iron block will work just fine. If you're shooting for an 8.50 1/4 mile car or faster, I'd go with the LSX block. Bob
What he said.
Old Nov 19, 2008 | 11:39 AM
  #32
ChevyChad's Avatar
gratz for making it into the 25% man sick times!
