F1-C F-body installation problem ! help
Old Nov 20, 2008 | 02:33 PM
vette_c6's Avatar
Default F1-C F-body installation problem ! help
when i install the F1-c it is hitting the Generator of the car
both of them are on the Driver Side
so its a little bit forwd not sitting in the right place
note : i have forwded the Water Radiator to the front
any iades for this F1-C for Camaro ?
please answer me and send me a Photo
Old Nov 20, 2008 | 02:35 PM
TNTramair's Avatar
if you provide us with a photo of the set up someone may be able to point out the problem..FYI.
Old Nov 20, 2008 | 02:51 PM
Inspector12's Avatar
TT-TECH Veteran
Fits fine I didn't have any clearance issues GL!
Old Nov 20, 2008 | 03:56 PM
firehawk123's Avatar
have some pic for us and some one will help you on it , or i will come to you tomorrow and see whats going on ,, as far as i know that you have to push the radiator to the front so you can clear that but from the generator i never heard about it maybe you have the blower in the rong dirction .
Old Nov 20, 2008 | 04:36 PM
NAVY's Avatar
Angry
i will go step by step installation manual/instructions for F-body Procharger F1-C
The same problem .
I used this manual http://www.exoticperformanceplus.com...html?item=1043
Old Nov 20, 2008 | 06:51 PM
EPP's Avatar
EPP
You may just need to reclock the blower. Jassim can help you with that. Bob
Old Nov 21, 2008 | 03:24 AM
NAVY's Avatar
Question
i want see what can you do Jassim
I hope install wrong
Old Nov 21, 2008 | 12:41 PM
every thing was fix ,, when he receved the head unit it came with two washers behind the pully so we took one out and it fix the problem .
good luck with the install .
Old Nov 21, 2008 | 07:29 PM
NAVY's Avatar
thanks Jassim to hlp me
Old Nov 21, 2008 | 11:35 PM
you welcome .
