Twin or Single turbo system for a 427 or 454ci
Who helped you choose parts??
It looks to be you didnt research what it takes to make 750-800rwhp....
If you want to run 7's (and still lift heads like crazy) then some of the parts will work well togeather...
why waste the $$ on a LSX block to run 4 bolt heads..... yes the cubes are there but the bigest gain from an LSX block is the provisions for 6 head bolts per cyl.
That way u can keep the heads down while running more boost.
Like most have said....... a $3500-4K short block with $2300 heads and an LS6 intake with a 85-88mm turbo can make that power on pump 93.
The parts you have chosen are awsome pieces that would make up two diferent motors....... an awsome N/A motor... solid roller with the C5R heads and the start of an awsome FI motor....
who's going to build the motor???
Id sit down with them and plan the build/motor out with them.
Kyle
HKE will be building the engine. But you guys are right the C5R setup would be better suited for a NA. I have a LS3 that I just bought from the salvage. I should consider building this engine instead.
