A2W on street car?
[/QUOTE]Relax..I know what you are saying..I was messing with you....BTW...who doesn't have a 1000hp nowadays..
The only advantages I see to a2w is...
1. The ability to add ice when needed
2. Even though you have more parts to make the system work properly on a street car. The parts are often smaller in physical size and can make packaging easier.
Mighty, have you ever measured back pressure across your I/C core? Or have noticed higher intake temps than others using the same set-up? I'd say you are pushing it a bit beyond it's means.
all i know is that for a 900 horse core its doing an awesome job over 1100.
a log i have when using ice over a 1/4 pass shows the inlet temp just comes back up to ambient by end of the pass at 21psi
http://i269.photobucket.com/albums/j...Y/DSC00121.jpg
http://i269.photobucket.com/albums/j...Y/DSC00120.jpg
http://i269.photobucket.com/albums/j...Y/DSC00119.jpg
http://i269.photobucket.com/albums/j...Y/DSC00118.jpg
http://i269.photobucket.com/albums/j...Y/DSC00100.jpg
Here are pics of the old ATW ....
http://i269.photobucket.com/albums/j...Y/DSCN2973.jpg
There's a lot of guys making some big power(around 1000 horse or more)in this thread. I run an OFI kit with a A2W IC and have to agree with those who run a TTI race kit and say a properly setup A2W setup has major advantages over a A2A. The water never gets hot if you have a properly sized & placed heat exchanger and you can bring the cold air with you.
otherwhitemeat: I really dont know a whole lot about volume/flow, but that A2W you were using looks really undersized for the power your making. Looks like 2 4x4x10 cores welded ontop of each other, and if your beating 8.90 cars, you need a 1500 hp core.
room temp. water will conduct heat away better than room temp. air period
water system is heavier more complicated and more expensive. ALSO works better all scenarios outside of roadcourse where the water cannot cool down quick enough.
I log a run this summer with the air temps starting at 76 degs and at the end of the run it was at 78 degs..that was with the ATA and the ez94mm at 27psi....If that dont say anything then I guess I'm done.
127mph in the 1/8......... spun a bit out of the hole on radials and only ran a 5.7 1/8
Popped a head gasket and havent had it back togeather since....
One of these days...... my son was born and i had to put more important things up front...... i know alot of you know what i mean.....
Kyle
Kyle
To the op. Would a small fan help a a2w intercooler in stop and go traffic? I wonder if you can spray no2 inside the water box befor each run
and our cars dont generally get cool down time until were going home or the action is over. Many guys around here run a IC and METH or nitrous to help cool the IAT's
Our systems might not need to work as hard (as say someone's in Florida or a warmer area) for as long of a part of the year, But they DO need to work as good at certain times of the summer.Lets say for example your using 4" tubing... that has a cross sectional area of approx. 12.5" square. now lets say that you need 15 feet (180 inches) of tubing to plumb from your turbo through the IC and to the TB... 180" x 12.5"^2 = 2250 cubic inches. A CUBIC FOOT (like the one you seem to be so famaliar with) has exactly 1,728 cubic INCHES... so now if we take the 2250 cubic inches of tubing between the turbo and the TB mentioned earlier and divide it by the 1,728 Cubic inches within a cubic foot we get 1.30 CUBIC FEET!
Fact, its simple math. 1BadAction...
And as far as the Bugatti goes... Isnt that a 2 million dollar car??? Most of us are talking about our daily driver cars or our budget builds in these forums... I am sure that there is a forum somewhere that could use your insights on cars that cost 100 times more than most of us spend on our cars, Oh ****... there's that 100 number coming back again...
I am reading this thread because i am interested in what happens in the real world condiitions. My real world conditions mean that there is not a race track within two and a half hours from where I live (no time for ice on the street) and even that track isnt the greatest. MN has a LOT of street racing action because of this and the cars are getting faster than ever and costing more and more. I am, to a certain extent, interested in bang for the buck mods, reliability, and effectiveness. I dont have a RACE car, and like many people I am more interested in a streetable setup. It seems like nearly everybody has a street rod of some sort... MN street racing is taken pretty seriously, afterall the Car Craft summer nationals are held here for a reason!
I am getting some great info here and I really appreciate it! But for those of you who are blowing smoke for whatever reason... Please save your time.
What this thread could use is (more) numbers. I dont have a turbo car... yet. But for those of you who do and who can or who already are sharing your IAT numbers and other intelligent info, Thank YOU!
From what I already know and what I have read about, I think that either setup can work really well if designed properly to handle the job at task
we werent allowed to pop the hood or touch the intercooler during the passes
