cutting out at wot
Old Dec 15, 2008 | 11:46 AM
collum's Avatar
Default cutting out at wot
my setup is a 2002 trans am w/ stock ls1 block, ls6 heads and cam, 42lbs injectors and t67 rear turbo, it has been fine untill today, at wot the car cuts in and out, like I was letting off of the throttle. at partial throttle it seems fine, and i'm throwing no codes any idea's
Old Dec 15, 2008 | 12:20 PM
98noscamaross's Avatar
It sounds like you need to change the fuel filter to me.
Old Dec 15, 2008 | 12:44 PM
CHRISPY's Avatar
What plugs are you running and what gap? Might be blowing out the spark...
Old Dec 15, 2008 | 01:28 PM
RooRnZ28's Avatar
did you do a visual check to make sure that everything is connected? are you running a MAF?
Old Dec 15, 2008 | 07:41 PM
collum's Avatar
tr6 plugs undergapped, 255 intank pump, wed when i get time i'm going to check plugs and filter, and fuel preasure hopping it is not the pump, i just thougt someone might have ideas what else to check, yes i am runing maf
Old Dec 15, 2008 | 10:24 PM
Silver_TransAm's Avatar
check for oil on the maf sensor.
Old Dec 17, 2008 | 04:36 PM
collum's Avatar
I think that was it, i cleaned the maf and replaced the fuel filter also (but it only had around 10,000 miles on it) and the car is running great, thanks everyone for the help
