8 sec. LS turbo engine buildup
I thought it would be cool to build a LS1tech motor with help and insite from it's 7, 8 and 9 second members. I tried a search and didn't find anything like this... SO...
I just got back from PRI and I'm amazed at all the cool stuff that's coming out for the LS series motors. I have decided to take out the 427CI BBC in my 70 Chevelle and build up a turboed LS motor. I would like to build a "best bang for the buck" motor that uses as much factory stuff available, as long as it will support 1000+/- hp. This is a street car with 3.73's, T400 and full weight that will have fuel injection and A/C. I would like to avoid the LSX stuff for price reasons and I'm thinking gen 4 stuff. I have most of this figured out on paper but was looking for validation. If I'm way off on my theories then let me know why. I will try and ask only a few questions at a time until it's all down on paper.
Now for the questions:
What block would be best? (iron or alum)
What stroke and rod combo will be best for a 4" bore, keeping the piston compression height in mind? What brand?
What heads would be best? (LS3, L92, other or aftermarket)
i would go with a lq9. you can get a forged short block for about 3500bucks. and i think if you are shooting for 1000hp i would go with an iron block (an lq9 is iron)
good luck with your build.
I have a 509ci w/twin 4788's that will make over 2000hp. That is my limited mileage Pro Street car.
This is my unlimited mileage street car, I won't have a problem making 1000hp. It's not hard to do when you pick the right parts.
I haven't found the LQ9 short block in the GM book. Is that similar to the LS9? It sounds like something I want to look into.
http://www.speedinc.com/enginepackages.cfm
i think they are a sponsor, if not i apologize for posting links
we did 8's with a simple 6L iron block, 408ci, hand ported 241 heads, 1/2 head studs... made around 1200 flywheel HP with 2x 66mm turbos..
will be aiming for 7's with the same setup
So if an iron block is superior to factory aluminum in my application then, is there any prep work that needs to be done to it besides the usual machining?
