ordered 370 from speedinc
Old Dec 19, 2008 | 01:18 PM
99Z28LS1's Avatar
*** UPDATE*** talking with ForcedInductions on ordering a TC78 as we speak!
Old Dec 19, 2008 | 02:59 PM
Big Bird WS6's Avatar
i got an APS kit that would do great with that motor.
Old Dec 19, 2008 | 10:21 PM
99Z28LS1's Avatar
Thanx, but i would like to stay with a single turbo
***UPDATE*** The TC78 is on order!
Old Dec 20, 2008 | 09:15 AM
danimal95's Avatar
*** please keep in mind that I have no aspirations for taking this car into the 9's or 8's at the moment and it'll stay a 6 speed until i can afford to build a TH400, I just want to come across some liter bikes and supras and show them what I can do from a roll ***
good luck with the build,although why do you think you wont be able to get in the 9's with a 6spd?
Old Dec 20, 2008 | 01:05 PM
99Z28LS1's Avatar
I know its possible to get into the 9's with the 6 speed, but im not building the car for the track. straight highway use
Old Dec 21, 2008 | 10:24 AM
danimal95's Avatar
mine is far from a purpose built track car,almost the opposite,but a set of slicks goes along wayjust hate to see another 6spd car changed over in the quest for a good e.t.,when it is very attainable as just that
Old Dec 21, 2008 | 11:35 AM
MeanYellowZ's Avatar
I was gonna offer up one of my new TC78's for sale, but it sounds like you got one coming......unless the one you have coming happens to be the one Im sending out for ForcedInductions....hmmmmm
Old Dec 21, 2008 | 12:12 PM
99Z28LS1's Avatar
I wonder..... i hope this turbo carries me to atleast 700rwhp
I will be moving the turbo up front once I learn to weld and bend metal, I would love to build my own kit
Old Dec 22, 2008 | 06:47 PM
99Z28LS1's Avatar
since im only used to running with a waste gate spring, how would i select a certain psi? boost controller? or spring to a certain psi?
Old Dec 22, 2008 | 06:58 PM
black98ws6ta's Avatar
You can run the spring that will make the amount of boost you want or run a boost controller and make up to 2-3 x's as much as the spring pressure.
Old Dec 22, 2008 | 07:06 PM
99Z28LS1's Avatar
so basically i need to order a boost controller.... i would hate to have the car gated to 15psi for example when i only need to run 10 or i wanted to run more than 15. i'd like to have the car gated for 10 and control the boost up to 20psi. a boost controller is the next purchase
