hp tuners 2 bar
hp tuners 2 bar
im tuning with hp tuners for the first time and a realized that on the scanner my map signal pegs at 105 kpa, ive got a 2 bar sensor ( at least i am supose to) and the 2 bar sd upgrade. is there a setting on the scanner that i have to change to make it read over 1 bar? the vcm scanner reads right with my boost gauge right up to 105 kpa. sorry if this is a dumb question, i tried searching
You have to change the scale on the guage in the scanner. Right click on the guage and select properties. Set the max to 210 as opposed to 105 and then save the changes to the configuration.
will this automatically be used for my afr error histogram if i get rid of the 1 bar pid?
