85 MM LS2 or larger MAF?
Old Nov 8, 2009 | 10:18 AM
98Z28CobraKiller's Avatar
Restricted User
Originally Posted by The Fugitive
is there a problem with going 3 bar right from the start even working with low boost? Or is it progressive and I have to work my way up to a 3 bar?
The only down side is reduced VE resolution. There is still more resolution than the aftermarket systems so it's really not a big deal.
Old Nov 8, 2009 | 10:19 AM
Restricted User
If I were the tuner involved in this build, I'd insist on speed density (SD).
Old Nov 8, 2009 | 10:24 AM
Restricted User
Originally Posted by 99Ls1fever
Sorry to ask but what is SD? I searched for this topic " 100mm MAF sensors" cause at the track I am running forced induction with spray and my tuner said to look into a lingenfelter 100mm maf because my stock one isnt keeping up with my car. I was just checking to see what is the best route and what SD Means? thanks
SD is Speed Density. The car does not rely on a MAF to tell it how to fuel. Instead it uses manifold pressure (MAP sensor) vs RPM to deliver fueling.
