76mm ideal size turbo for an LS2?
Old Jan 9, 2009 | 09:50 PM
Snyper's Avatar
Default 76mm ideal size turbo for an LS2?
Im looking to turbo charge my LS2 350z.....wondering what kind of turbo would be idea. I know that the 76 seems to be perfect for an LS1..just wondering if it would choke out an LS2....
Old Jan 9, 2009 | 10:10 PM
TurboAv's Avatar
It was recommended to me today that for a stock cube LS2 to go with the TC78 for street use and a PT88 for all out drag racing. Even with the TC78 you are looking at around 800rwhp.
Old Jan 9, 2009 | 10:54 PM
Snyper's Avatar
whats spool times for the 78 and 88?
Old Jan 10, 2009 | 08:00 PM
bboyferal's Avatar
I don't know exactly, but I imagine they'd be like the spool times of a 76 on an LS1? If so, that's as good as it can get without outflowing a turbo IMO.
Old Jan 10, 2009 | 09:38 PM
TurboAv's Avatar
Not sure on the 78 but he said the PT-88 would be full boost around 3800rpm.
Old Jan 10, 2009 | 09:44 PM
LASTLS1's Avatar
6 Second Club Moderator
Twin 76's seem to work well.
Old Jan 10, 2009 | 10:08 PM
Snyper's Avatar
I want a turbo that makes full boost around 3,400 up to 6500..i dont plan on spinning the motor past 6500 even after I build it.. if a 76mm will work without choking the motor then id rather stick with that one..anyone have a side by side comparison of the 76 and 88 in terms of actual size?
Old Jan 11, 2009 | 09:40 AM
hellbents10's Avatar
LS1Tech Sponsor
The TC76 will be full tilt before 3400, I have seen 10psi below 3k on the foot brake with a 370.
Old Jan 11, 2009 | 11:52 AM
Snyper's Avatar
hmm that might not actually be bad...hellbents..is that with an LS1 or LS2?
Old Jan 11, 2009 | 12:07 PM
eviltwin_1987's Avatar
he says the size in this reply
you should stop thinking ls1/ls2 and start thinking ci.
Old Jan 11, 2009 | 02:37 PM
Snyper's Avatar
346/364..i know the ci's. And thats exactly why I was bringing up different motors. I know an LS1(346) works really well with a 76mm. I was told by a few people the LS2(364) might be a little too big for the 76. Thanks for the informative post though.I wasnt sure if he was talking about the 370..or an LS motor in general.
Old Jan 11, 2009 | 05:06 PM
Louis's Avatar
So many things affect spool, its really a vague question. Down pipe size, compression, gear, ignition advance, AFR....
76mm would be perfect for what it sounds like you want to do.... but only you know what you want to do....
Old Jan 11, 2009 | 06:59 PM
Snyper's Avatar
yeah thats what im thinking..maybe even the 78..not much of a difference..but every little bit counts. How much boost do these LS2s take on stock bottom ends?
Old Jan 11, 2009 | 07:25 PM
TurboAv's Avatar
I wouldn't run boost without at least better rod bolts and even then anything over 10psi is pushing it IMO. That's why I want to just put forged rods and pistons in my motor. Since I only have 27k on the car I should just be able to hone it and use stock sized pistons.
Old Jan 11, 2009 | 08:22 PM
Snyper's Avatar
Im only looking for 6psi max on the stock motor...just so everything is up and running.
Old Jan 11, 2009 | 10:41 PM
TurboAv's Avatar
You will be fine at 6 psi. Just don't rev the crap out of it with stock rod bolts.
Old Jan 11, 2009 | 10:43 PM
Snyper's Avatar
I better get the rod bolts...ill be beating the **** out of this thing. Which bolts do I go with? The Ls1 bolts?
Old Jan 11, 2009 | 10:54 PM
the arp ls1 bolts
Old Jan 12, 2009 | 11:50 AM
DrTurbo's Avatar
LS1TECH Sponsor
Yes the TC on the street is HARD to beat. Spools stupid fast.
Old Jan 12, 2009 | 01:40 PM
fenix999's Avatar
The turbonetics TC76/TC78 units will be MUCH better to fabricate a custom turbo kit with since its quite a bit smaller overall than the pte88. Its power and spooling capabilities along with the ease of fabrication in tighttt spaces is the reason why so many pple use this turbo. The Pte88 will be a better unit for bigger, more powerful setups seeing much more boost (ie drag racing like mentioned)...its a bad **** for what it is though! Another thing, built LS2's have been taken over 1200rwhp with 22+ psi of boost (look around in the forced induction section, plenty of crazy setups are posted). Stock LS2's have been taken to about 15 psi but some have failures and some live a little while before they grenade On a completely stock LS2, i'd say to run no more than 8-10psi and put at least arp rod bolts and arp head bolts/studs in it. With perfect tuning and other things considered it will last "forever". Good luck with the build man
