STS - separate turbo oil system Qs
Old Jan 26, 2009 | 10:56 AM
sujomatt's Avatar
Originally Posted by Zombie
You guys really love to complicate things.
Care to go a little deeper than that? lol.
It sounds like I can just have a cooler, 2 pumps, and a tank in the trunk. I can check the oil level by hand - so i dont really think id need a sensor for that. also, if there is a thermostat way of cooling that sounds like a great idea.. but trying to do a search on that i am coming up empty handed.
On the plus side my friend is a very good mechanic, so we can change things on the fly so to speak. lol
Old Jan 26, 2009 | 11:08 AM
Mike in LA's Avatar
The tank I have coming has a hookup for a sight glass, so I'll be using that for the oil level.
Old Jan 26, 2009 | 01:57 PM
Zombie's Avatar
1. not one, but two pumps to fail
2. Have to get the oil up to working temp
3. if feed pump fails kiss your CHRA bearings good bye.
4. extra tank, one more thing to check constantly
5. all the extra cost involved
6. extra weight
Pump failure is the biggest reason not to do this setup. The KISS method really should apply to the scavange pump/feed setup as it is a critical component. The mechanical setup from the engine is much more reliable.
Old Jan 26, 2009 | 03:28 PM
witry's Avatar
the KISS method holy crap i havent heard anybody say that since highschool auto shop teacher but hey it true dont complicate it
Old Jan 26, 2009 | 04:06 PM
sujomatt's Avatar
so in other words tap the oil pan and call it a day?
Old Jan 26, 2009 | 05:10 PM
witry's Avatar
yep use the motor as a feed with a restrictor and use like a mocal or shurflow pump and you shouldnt have any problems
Old Jan 26, 2009 | 06:17 PM
OUTLAWZ RACING's Avatar
Thats how I run mine. I also have a light and a buzzer for pump failure. I thought about a seprate system but hey 2q of oil in my trunk is not cool. Plus all the extralines to weep oil over time and all that ****. Tap the pan for the return and be done with it.
Old Jan 26, 2009 | 10:14 PM
2002ws-6's Avatar
Heres the system I built more than three years ago, and around 10,000 miles of driving.
1. Oil drain pan/resovior is from a porsche 996 turbo
2. Oil pump is a brass gear driven pump similar to what you get for the return pump from STS
3. oil pressure guage running in my center vent
4. Oil goes into a B&M cooler with a thermostat controlled fan.
5 Oil goes to the turbo inlet which also has a small needle and seat bypass to adjust pressure.
6. The little Black box is a PWM DC motor controller. It has two speeds that switch at .5 psi. On a cold morning the oil pressure is about 30psi, when it warms up it sits around 15-20, which i have been told is plenty for a turbo thats not spooling. at .5 psi the PWM kicks up the voltage and give around 40psi when the system is warm.
The whole system was a little pricey about $1000.00 but the only part that has ever failed was the PWM, and that was because I used one only intended for 10A max, the new one is designed for 24A and have not had any other issues.
Also I just checked my MP t-70 has no shaft play
Old Jan 27, 2009 | 07:45 AM
Mike in LA's Avatar
Thank you 2002ws-6 that is a great discription and with pics
PM sent
Old Jan 27, 2009 | 03:05 PM
RsSean's Avatar
That is what I am talking about. Very nice set up.
Old Jan 27, 2009 | 10:52 PM
Dr.Charles27's Avatar
I'm doing a "butt mount" Holset HX50 with absoultly no scavenging pump. This is my theory; and hopefully it will work.
I've installed a 15 gallon aluminum fuel cell in my trunk and eliminated my stock gas tank. "My theory" is that if I mount the turbo high enough giving me enough downward pitch back to the bottom of the pan, then no problem.
Go ahead, Im ready for feedback (neg or pos)
Old Jan 27, 2009 | 11:02 PM
  #32
Default Relocation
I just wanted to show you guys my surgical procedure that I went through so far. With the stock gas tank removed I've gained 12 inches, thats right 12 inches without the use of pills, creams, or streneous exercises. (of clearance I mean) LOL!
Attached Thumbnails STS - separate turbo oil system Qs-before-surgical-procedure.jpg   STS - separate turbo oil system Qs-forming-metal-cell.jpg   STS - separate turbo oil system Qs-formed-floor-welded.jpg   STS - separate turbo oil system Qs-finished-metal.jpg   STS - separate turbo oil system Qs-cell-finished.jpg
Old Jan 27, 2009 | 11:13 PM
  #33
This is my new intake port for my hx55 the old filler door was removed and i fabbed up a new semi-attractive looking screened intake. The best part is that this is the only one I've seen like this and I have a straight shot from the opening to the turbo through a conical air filter and 4 inch pipe.
Attached Thumbnails STS - separate turbo oil system Qs-intake-started.jpg   STS - separate turbo oil system Qs-rough-view-intake.jpg   STS - separate turbo oil system Qs-studs-welded-intake.jpg   STS - separate turbo oil system Qs-air-intake-.jpg
Old Jan 27, 2009 | 11:46 PM
  #34
Mike in LA's Avatar
Thats an interesting build you are working on. The new fuel cell looks great, I'm curious as to what others will say about it. Good luck and keep us posted.
Old Jan 28, 2009 | 12:11 AM
  #35
2002ws-6's Avatar
replied to PM's and found one more picture this is with the Tial 44mm wastegate leading to the drivers side tail pipe
Old Jan 28, 2009 | 07:03 AM
  #36
thanks Mike, this my first forced induced project ever. Im moving a little slow due to finances, still having intent to hang the hair dryer within the next week (time permitting).
Im curious to hear other thoughts to.
Old Jan 28, 2009 | 10:06 AM
  #37
Zombie's Avatar
How will you compensate for the effect of accelleration? You will have drain problems without a pump.
Old Jan 28, 2009 | 02:22 PM
  #38
Im thinking if I trapped the line at some point of return and installed the discharge into the side of the pan or front rather than the rear I should be ok. (I hope) Im going to mock it up with a roll of soft 3/8 aluminum tubing just to see what kind of foward pitch I can get. If Im not satisfied I just might consider a seperate oiling system, kinda like that idea.
Old Jan 31, 2009 | 02:27 AM
  #39
bnio's Avatar
Back to the orig post, you shouldn't separate the oiling since mainly because of heat. Your oil should be no less than 160 degrees before you load the engine and turbos of course are no exception. If you separate the systems you have a very difficult time regulating heat and making sure heat is maintained and flow isn't interrupted. Also if you want a bullet proof setup go with a drysump pump system, like one sized for a rear end, single stage should be fine. Drive it off the motor and be done with it. If the motor turns the pump turns. DONE! RELIABLE! FORGET ABOUT IT! Also anything can fail anytime. Run steel lines from front to back, secure them well and nothing will happen. How many times has your exhaust system been torn off? Let me guess not one time, right? So what are your chances for your oiling lines getting torn off? Most likely none. I have been reading Zombie's posts and he right, use the K.I.S.S. method and enjoy.
Old Jan 31, 2009 | 03:00 AM
  #40
bnio's Avatar
Now to the gravity drain post from the rear. I don't want to be a downer but I feel you will be buying some sort of scavenge pump in order to make this work. Draining from that far back will be difficult. Since it isn't a pressurized line back to the motor or a vacuum system in the engines sump(drysump) it is going to be difficult to get the oil to reliably get back to the engine sump. Of course liquids will seek level so as long as the turbo is a decent height above the oil level in the engine it technically should drain. But here is the rub, its oil and things don't always work the way you think they should. Oil doesn't flow as freely as water. As you accelerate it will back up in the line since the whole system is open to the same atmospheric pressure and you will be applying acceleration force to the mass of oil. Think of a drink in your cup holder when you accelerate. But the other side, if you think you can make it with enough fall to get to the engine and drain go for it. If it doesn't work you know you need to by a scavenge pump. One thing also you may want to look at adding an accumulation tank to handle increase oil volume if you do encounter intermittent draining issues. This may help your gravity drain system by allowing it to build volume so it doesn't back up the line as quickly if it even becomes a problem. Actually most systems should have an accumulation tank as a buffer for these kind of setups.
