turbo with TH400
Old Jan 27, 2009 | 01:59 PM
Zombie's Avatar
Originally Posted by forcd ind
you can add 2.75 first gear in the 400, will help with street gears in the rear, but their limited to around 800 flywheel hp, and costs around $600 for the gears
you can build a 4l80e on a budget, if you use a manuel v/b, (unless you have a computer now)and build the trans yourself, for about the same money as a 400
You don't need a 2.75 first gear set, my 3850lb beast moves out just fine with it's 2.48 set. I doubt most people would even be able to tell the difference.
Old Jan 28, 2009 | 12:09 PM
Sandmann120's Avatar
I've got to agree with Zombie. The TH400 is completely streetable. I've been running one in my car for a few years now, and have had great luck with it. Some of it may also have to do with what valve body you use, as mine can be a little cantankerous at times in traffic, but its nothing major. This is even with a loose converter and a healthy rear gear to keep my cam happy. Plenty of highway cruising.
Old Jan 28, 2009 | 03:40 PM
NA$TY-TA's Avatar
If its going to be a 408 car why even go with a th400........
Go with a Rossler built Powerglide.
Takes less power turn and less of a HP loss.
BMR's crossbrace works for a perfect mount.
With a big cubed turbo car your not going to see a big difference because of the TQ the motor will make.
Opt for a 1.80 1st gear vice the 1.76....
Another plus is one shift......
With a turbo the fall off between gear isnt hard on the setup at all... 1.80 1st and 1:1 2nd
The reason i know the above is because i did it........ drives real nice on the street.
3.54 rear gear and a 28" tall radial.
I would spin 2700 rpm's at 62mph.... not bad at all compared to when the car was a 4L60E car with 3.73's it would be 2500 @ 70 MPH....
Cars came from the factory for years with powerglides......
Any high HP car i ever build in the future will have one
I ran a Chance convertor also and Zombie..... if Chance was gunna sell you a bolt togeather for $1600 id of bought 3-4 of them at that price because the Bolt togeathers retail for $3K each.
His weld togeathers are $1600.......
Kyle
Old Jan 28, 2009 | 04:08 PM
patriotformula's Avatar
Originally Posted by elias_799
th400 is not very streetable, it is a 3 speed auto and i think it would get a little annoying on the highway, yes it all depends on the rear end ration and all that but a 4 speed auto like a 4l60e would be a better street tranny.
Yeah I've never known a th400 to be terribly unstreetable unless it has like a 5000 stall or something. Unless you are doing a bunch of highway driving a th400 is certainly streetable, and actually a pretty fun transmission to drive with a mvb and a TB...
Old Jan 28, 2009 | 06:52 PM
longrange4u's Avatar
Kyle
Hahahaha yea! I was gonna say that is what I paid for my weld together!! (Damn close anyways)
Old Jan 28, 2009 | 07:32 PM
Zombie's Avatar
Kyle
Originally Posted by Zombie
Chance quoted me $1600 for their weld together which was a bit above my budget. Ended up going PTC for $950 and absolutely love it.
I'd probably buy a bolt together for $1600 too, but I said the price was for a weld together. Don't know where you saw I said bolt together, can't find it. If I did I meant weld together.
Old May 18, 2009 | 09:50 PM
xxbottlefedxx's Avatar
LISTEN go with PERFORMABUILT http://performabuilt.com/Converters052008.html
they are a sponsor and ls1tech is good about haing reliable sponsorscheck out there site you will be impressed with the detail and price O'yea they also sell converters to
