turbo with TH400
Old 01-25-2009, 01:14 PM
bgblockelcamino's Avatar
Default turbo with TH400
converting a turbo car to th400. but wondering what companies do you prefer? right now it is GT4202 on a stock LS1 right now i was thinking of 3000 stall as the car is street driven a bit and will not have lockup anymore. just wondering what everyone's company reccomendations and what stall would be a good compromise for a street/some track time car.
Old 01-25-2009, 01:23 PM
Yank Eliminator 10-350/400 LS1
this is one that i was leaning towards
Old 01-25-2009, 01:45 PM
TurboAv's Avatar
Give FTI a call. They built my TH400 and the converter. They do converters for cars that are 2500hp, so I think they can handle it. Also do a search for Trakday on here. He has one of their TH400 converters in his twin turbo stroker GTO.
Old 01-25-2009, 01:49 PM
night ryder's Avatar
call a good converter place and they will set you up with the right converter. if they do not ask alot of questions about your setup, then hang up the phone. they will want everything including stroke, cam specs, displacement, everything.
Old 01-25-2009, 02:39 PM
longrange4u's Avatar
Neal Chance converters are the best avail if you are willing to pay the $
Old 01-25-2009, 04:39 PM
Zombie's Avatar
Neal Chance is def the biggest name in race converters and their price shows it. A lot of turbo guys including myself like PTC. Chance quoted me $1600 for their weld together which was a bit above my budget. Ended up going PTC for $950 and absolutely love it.
For my trans I'm running a TH400 built by Rossler. Have 200+ passes on it now and 4000+ miles of street driving. Still works like new and I've only had to change the fluid three times.
Old 01-25-2009, 05:00 PM
Sluggish's Avatar
What level trans did you go with?
Old 01-25-2009, 07:11 PM
right now the car is a 6 spd and works perfect. so customer and i decided to sell the trans while it still worked fine and worth money. i have had good luck with th400. just never planned on putting this much power through one.
Old 01-25-2009, 07:29 PM
vandal0-0's Avatar
I went with the PTC also.
Old 01-25-2009, 07:33 PM
elias_799's Avatar
if the car is street driven why not go with a built 4l80e ?
Old 01-25-2009, 07:49 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
^ My exact thoughts. You could run a built 60e at those power levels. What are the future plans for the car? If they just plan on sticking with a stock engine and the 4202 why even bother?
Old 01-25-2009, 10:06 PM
elias_799's Avatar
th400 is not very streetable, it is a 3 speed auto and i think it would get a little annoying on the highway, yes it all depends on the rear end ration and all that but a 4 speed auto like a 4l60e would be a better street tranny.
Old 01-25-2009, 10:33 PM
there is a forged 408 in the works. but still not in budget. so for this year the customer would like to drive it somewhat reliably. i am not a fan of 60e. and trying to build an 80 is a bit more money.
as for th400 don't know why it would not be streetable. it has 3:50 gear in rear. the old setup was 456 with t rex cam so the customer is used to higher RPM cruising.
Old 01-25-2009, 11:57 PM
Zombie's Avatar
I don't mean to break your heart, but the th400 is perfectly streetable, you just need to think outside of the box when dong the setup. I cruise 70mph at 2400 rpms. Thats about the same as a 4l60e car with a 3.23 rear end... in overdrive.
For those wondering about my Rossler trans I think it's a level 2, but don't remember. Base model was $1200 but ended up being $2000 shipped after adding the speedo setup, trans brake and keeping the 2nd gear intermediate band (for safety since finish most of my races in 2nd gear).
Old 01-26-2009, 06:45 PM
elias_799's Avatar
it all depends on the rear end gear you use.
Old 01-27-2009, 11:25 AM
LS1TECH Sponsor
DrTurbo's Avatar
Call PTC, or look for a friend of ours on this board named Dusty Bradford. He races EZ street and will take care of you on a PTC convertor. For the price, they can't be beat IMHO.
Old 01-27-2009, 12:26 PM
Zombie's Avatar
Dusty did my converter. I never knew a converter could be this good.
Old 01-27-2009, 12:35 PM
99Ws6TransAm's Avatar
PTC does a great job.
Old 01-27-2009, 12:45 PM
REGALIS's Avatar
Since its a turbo car, chances are the rear gear ratio is going to be fairly highway friendly..
Old 01-27-2009, 01:06 PM
forcd ind's Avatar
you can add 2.75 first gear in the 400, will help with street gears in the rear, but their limited to around 800 flywheel hp, and costs around $600 for the gears
you can build a 4l80e on a budget, if you use a manuel v/b, (unless you have a computer now)and build the trans yourself, for about the same money as a 400
Quick Reply: turbo with TH400
