842rwhp @13.5psi Another APS TT C6 ZO6 by Speed Inc.
navymitch- the boost per gear switch setup? Not sure when they are going to have them ready.
Turbo 6.0- Thanks!
edit- Van is sending some better tires so I'll re-dyno in a few days to see what she does with some more traction.
Turbo 6.0- Thanks!
I didn't take any installed pics. It bolts down with the same bolts that hold the shifter base to the torque tube.
A plate that's held on by the shift linkage bolt actuates the switches.
Attached is a pic of the first version I made on my car. It used a longer bolt to actuate the switches but eventually broke one of them which is why I went to roller switches and an actuating plate.
Here's the dyno sheet so far.
You can see by looking at the torque curve that it was spinning a bit on the rollers.
Next week we're mounting up some sticky tires and likely installing a set of the new ford 80lb injectors (about 97lb/hr @58psi) and putting it back up on the dyno.
#33
I've never heard of either style clip that they are talking about on those or these adapters that they sell- http://www.fordracingparts.com/parts...tKeyField=9669
Do either of them plug into our factory wiring harness or where do we get those connectors at?
#36
I re-tuned the car today with the new ford injectors and they worked out great.
Made 939rwhp 877rwtq with 16.5psi boost. Still fighting a ton of tirespin with the PSC's. Injector duty cycle on that run just touched 80% with the air fuel ratio at 11.8-1.
