faster spool with same power
Old Jan 27, 2009 | 10:34 PM
DrTurbo's Avatar
LS1TECH Sponsor
Well the 2500 dollar turbos run ball bearing, water cooled and run larger housings which may make more power. Other then that its not (a lot) of difference. But some people like the added spool up with the ball bearing and the added HP they get from the larger housings. Its all about personal preference.
Old Jan 28, 2009 | 10:10 AM
Zombie's Avatar
Originally Posted by extremetoy
i was just curious whats out there... its a 6 speed and a rear mount.... see the graph to see spooling... about 2500 is when it starts and full boost around 4,000 on the dyno... i think its slightly sooner on the street
Ahh, the dreaded 6 speed lag. You running manifolds and wrapped exhaust? If you are spooling up 4000 on a POS dynojet you should be seeing full boost in 4th on the street 500-1000 rpms sooner, which would make your setup not laggy at all.
Old Feb 1, 2009 | 04:44 PM
Jeezer's Avatar
what turbos out there spool up faster and either make the same or more power than the tc76? still in the t4 flange
i run a B.w s375 and its said to be laggy but my stock ls1 spools it up real nice. im also running the1.01 hotside.
Old Nov 19, 2012 | 07:44 PM
burbalanche's Avatar
how do u like the s375?what kinda power u making?setup?
Old Nov 19, 2012 | 07:57 PM
LS1NOVA's Avatar
You realize the thread is 3 years old right?
