Which block? How many cubes?
Old Jan 26, 2009 | 08:04 PM
jeremym's Avatar
Default Which block? How many cubes?
I have a 98 ss 6 spd. I will be using a F1A running 14-16. I was thinking of doing a LS7 427 but seen a 418 LS3 or go with the old iron 408 I would like to go with alum block for weight. The LS7 is pricey and I know nothing about the LS3 block. What all would I have to do to get the Ls3 to work. Whats the price diff to.
Old Jan 26, 2009 | 08:29 PM
Shawn @ VA Speed's Avatar
I would go with the ls3 based engine,the ls3 is a really good block with thick sleeves.the other benefits are less weight than the iron block and cheaper than the ls7
Old Jan 26, 2009 | 09:46 PM
jeremym's Avatar
What all do you change to get the ls3 to work?
Old Jan 27, 2009 | 05:12 AM
EPP's Avatar
EPP
Check out our pricing on using an LS2 block.
http://www.exoticperformanceplus.com...html?item=1715 Bob
Here is a car that we used the above engine with an F-1A.
http://www.exoticperformanceplus.com...html?item=1714
Link to this car from my project car section.
http://www.exoticperformanceplus.com...Car.php?car=29 Bob
Old Jan 27, 2009 | 07:06 AM
frt and valley covers are different,have to use an extension harness on the cam and knock sensors,move knock sensors to bottom of block,really easly conversion.
