using ls1 edit need help tunning trubo car
thanks
wicked 1
__________________
1999 firehawk TA #61, yes, #61,
race 4L60 with a **** kit and vacuum modulator, mickey thompson10.5 26 16s et streets, 12 bolt 3:73 gears forged blower pistons 9.1cr, Eagle h-beam rods,heads are ported and polished, ls1 motorsports 15-18 psi singe turbo, ls1 edit tuning, comp cams 918 springs, 232/230/595/591/114 cam, ls6 aluminum intake, Magnaflow catback, Jegster 8 point cage and drive shaft loop, simpson 5 point harness, 275s nittos in the front and 315s in the back 3 2-1/16gauges boost,fuel,trans temp on pillar
