puttin the sts on.
Old Feb 9, 2009 | 10:01 AM
Schantin's Avatar
Originally Posted by Frost
safe amount of boost of a stock setup = 0 psi.
seriously.
x3. Get the supporting mods/tune installed w/ the turbo.
BTW, a manual boost controoler holds the wastegate spring closed to create higher boost levels than the wastegate alone (like 7PSI on a 5lb spring). It doesn't work the other way to reduce boost. Also 1lb of boost = approx 22hp. Would be the same as installing a lid on a stock intake.
