puttin the sts on.
Old Feb 5, 2009 | 06:57 PM
whitew01ws6's Avatar
Default puttin the sts on.
i know this isnt the RIGHT WAY but.... iam puttin the kit on next weekend. what my ? is how much if any boost can i run untuned if i drive her easy? anddddd iam buying a manuel boodt controller, my waste gate has a 5 lb spring in it. can i drop the boost to 1 psi? i will be on stock injectors and stock fuel pump for about a month. then it will be tuned and the right parts will be on.
dont say wait a month.... i cant....
Old Feb 5, 2009 | 07:40 PM
EPP's Avatar
EPP
As long as you drive like you are in a funeral procession you'll be okay. Bob
Old Feb 5, 2009 | 07:54 PM
elias_799's Avatar
wait a month, and get it tuned. it will be very tempting to step on it once you have the turbo on. if you are short on funds the last thing you want to do is rebuild your short block. good luck
Old Feb 5, 2009 | 09:30 PM
eviltwin_1987's Avatar
if your going to have to baby it all over the place you should just wait to put the sts stuff on. Why put it on when you wont be able to use it?
Old Feb 5, 2009 | 09:48 PM
GAKz28camaro's Avatar
You dont want to lean it out when you boost I would be careful or wait...
Old Feb 5, 2009 | 11:42 PM
SaultysHuggerSS's Avatar
if you put it on and run it 1psi or not its going to run like ****
Old Feb 6, 2009 | 03:12 AM
ALTRDTA's Avatar
I doubt he could get it to run only 1lb of boost without a major boost leak (which would cause the turbo to over spin anyways...)
I'd say if you can make time to get it on right before the tune go that route. But if you must get it on now to make sure you have enough time to wrap everything up for your tune then do that. But just make sure whatever you do, drive the car as little as possible, and also make sure you have a boost gauge to monitor whether or not you are hitting boost or not... I know I can feel it before I can even see it on my gauge as boost so I wouldn't be worried. But a newb to FI I'd be hesitant...
Old Feb 6, 2009 | 05:51 AM
Silver_TransAm's Avatar
Just take the wastegate off and you wont make any boost, it will just sound like you have a big exhaust leak.
Old Feb 6, 2009 | 07:50 AM
Frost's Avatar
safe amount of boost of a stock setup = 0 psi.
seriously.
Old Feb 6, 2009 | 08:06 AM
RsSean's Avatar
You should wait till you all the supporting mods to go along with it. If you have to pull out in traffic or something makes you get on the car you can risk damaging the motor. Does not sound like a good idea to me.
Old Feb 6, 2009 | 08:57 AM
sujomatt's Avatar
pretty good idea
Old Feb 6, 2009 | 05:08 PM
ALTRDTA's Avatar
Good point
Old Feb 6, 2009 | 05:55 PM
frcefed98's Avatar
= boost with untuned PCM.
= boost with tuned PCM.
Should be a no brainer.....and trust me there is NO ONE not ONE fool alive that will keep his foot out of it once a form of FI is bolted to the car....the temptation is too great
Old Feb 6, 2009 | 06:05 PM
Superman09's Avatar
LS1Tech Sponsor
what they said ^^^
Also about your boost control question.... no. You cannot go any lower than your spring pressure, only higher. If you have a 5 psi spring, you can use a MBC to raise it, but you won't be able to go below that 5. Hope this helps!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Old Feb 6, 2009 | 09:58 PM
OreoLt1's Avatar
seriously.
Old Feb 7, 2009 | 08:36 PM
OUTLAWZ RACING's Avatar
LOL!!! so true
Old Feb 7, 2009 | 11:42 PM
Mike in LA's Avatar
Don't risk it, do it the right way.
Old Feb 7, 2009 | 11:49 PM
'Trust''s Avatar
0.0 psi of boost.
Old Feb 8, 2009 | 03:14 AM
koolaid_kid's Avatar
Watch your EGT or AFR. If you do not have either, stay out of boost.
Old Feb 8, 2009 | 05:26 PM
t/a-Donnie's Avatar
If there's anything I've learned while working on cars(or doing anything for that matter), it's to be patient and be prepared. I would wait. When I get my kit on(soon), I'm going to wait for a good tune. The wastegate off would work, but will you actually do that? lol.
