SDCE tensioner Blew up
Old Feb 8, 2009 | 06:46 PM
BigBenz's Avatar
Default SDCE tensioner Blew up
Well I was coming home from a gun show that was about 70 miles away. I all of a sudden noticed i couldnt hear my SC anymore. I pulled over and found that the belt had slipped off. When i got home i put the belt back on and found it to be walking tawards the back of the car. So i started pulling the SC bracket off. this is what i found.
A crack, I prolly just over tightend the thing. I was trying to pull off the pulley thinking that i could just weld it, then this happend. With only a little force.
I guess i found out why my belt was walking around. I think that every time hit the gas the bolt would move a little then flex the tensioner. I cant belive how easy that tensioner snapped.
Anyways does anyone have any clue how much a new tensioner would be?
and has this happend to any one b4?
Old Feb 8, 2009 | 07:01 PM
elias_799's Avatar
wow, have not seen this before.
Old Feb 8, 2009 | 07:27 PM
BigBenz's Avatar
Yea its my fault. I over tightend the nut. and the movement cracked the housing.
Old Feb 8, 2009 | 07:40 PM
frcefed98's Avatar
Call up scott or wendy and get a replacement....I think its around 70 bucks. Kyle broke his from what I remember.
J
Old Feb 9, 2009 | 01:02 AM
1dirtyZ's Avatar
i broke mine too ( after about 30,000 miles of abuse and over torquing the nut )
i'm sure scott or wendy will get things in order for you
Old Feb 9, 2009 | 01:33 AM
BIG BAD BLACKSS's Avatar
Take it over to your local parts store and look for a match. I remember a thread on here that stated someone copied the SDCE setup and the tensioner was a common off the parts store shelf unit.
Old Feb 9, 2009 | 01:30 PM
jeremym's Avatar
Anybody else had this problem?
Old Feb 9, 2009 | 03:20 PM
Inspector12's Avatar
TT-TECH Veteran
J
Well they wanted to charge me $150 for a new one and wanted me to send my whole bracket back to them so I went and found the tentioner my self and make them myself if I mess it up but it has been holding for about a year now with out any problems so if you want to do it your self here is the autozone part number it was about $48 bucks 305201. GL!
Old Feb 9, 2009 | 04:22 PM
Aster's Avatar
This is why I designed my own tensioned bracket, I was worried this type of problem would occur. The way the SDCE is setup puts a large amount of strain on the tensioner housing with the pulley spaced out so far from the arm to clear the bracket. There is a reason tensioners keep the pulley right off the arm, so that the arm doesn't experience the twising/side load like that.
If you do a search on my name you'll find the post I made about my bracket.
Old Feb 9, 2009 | 04:42 PM
frcefed98's Avatar
I never broke mine or had any issues with it, I sold it to KP still in excellent condition too. I wonder if he ever broke it?
But there you go, 50 bucks and a PN and a short trip to Autozone and you are all set.
Old Feb 9, 2009 | 06:54 PM
jeremym's Avatar
What boost does this bracket break? I was thinking of using this bracket with a F1A running 14-16psi but I might just go Twin Turbo route.
Old Feb 9, 2009 | 08:11 PM
TT-TECH Veteran
I broke mine so it wasn't the design etc...
Old Feb 9, 2009 | 08:24 PM
jeremym's Avatar
How many have you broke?
Old Feb 9, 2009 | 11:22 PM
TT-TECH Veteran
Two. Both were from trying to tighten the belt so I made a design change on the third one and its been there ever since LOL! The first and second one I broke within 3 days of each other it was one of those self taught lessons on what not to do.
Old Feb 9, 2009 | 11:33 PM
firehawk618's Avatar
Anyone know the automotive application for that autozone tensioner?
I would sure like to have a spare ready to go just incase.
Thanks
Old Feb 10, 2009 | 12:35 AM
kp's Avatar
kp
Never had a problem in four years with the one I got from you so who knows.
Old Feb 10, 2009 | 06:08 AM
jeremym's Avatar
Can you have sdce beef the bracket up?
Old Feb 10, 2009 | 10:11 AM
Avengeance's Avatar
Theres a company that makes a steel J bracket.... cant remember the name right now. Trutech or something.
nm... just realized you meant a tensioner bracket.
Old Feb 10, 2009 | 10:15 PM
jeremym's Avatar
How many other people had this problem? I was going this route but now I might save and do a turbo
Old Feb 10, 2009 | 11:41 PM
frcefed98's Avatar
lol turbo's are a ton more problems than going SDCE/procharged route
Been there done that.
The problem doesn't lie with the design of the SDCE set up, but with the end user torquing the **** out of it and cracking the tensioners thin aluminum housing.
