Expecting FMIC from EPP this week can't wait
Old Feb 10, 2009 | 05:42 PM
B.Buster's Avatar
Talking Expecting FMIC from EPP this week can't wait
Been wanting to make this upgrade for a while. Just a couple of questions for those who have. What is the used dual IC system (3.5" ProCharger) worth with aluminum plenum? How much more timing will I be able to run with the cooler air to start with? Will retune in the spring. Only running 7#s for now.Thanks
Old Feb 10, 2009 | 06:17 PM
EPP's Avatar
EPP
It is on it's way, thanks for the order! It left the shop yesterday.
I have sold the used 3.5" twin intercooler kits for $500.00, STS turbo guys have bought them from me in the past. The alum plenum is worth around $100.00.
You might be able to squeeze another two degrees of timing out of it. Bob
Old Feb 10, 2009 | 07:44 PM
B.Buster's Avatar
Thanks Bob, 2 degrees can be alot as you know. Parts will be out and ready to sell by weekend. Only have about 10K ,still in mint condition.
Steve
Old Feb 11, 2009 | 05:00 AM
EPP's Avatar
EPP
Thumbs up
Steve
Steve, if anyone calls me on a used intercooler assembly, I'll send them your way. Bob
Old Feb 11, 2009 | 02:58 PM
LS1RedZ's Avatar
You will like it alot!! Ive got one. Its a nice setup for sure!
Old Feb 11, 2009 | 03:19 PM
LS1RedZ's Avatar
Saw that you had a Red Z28 like I do. Here are a couple of pics so you can see what it will look like.
Old Feb 11, 2009 | 04:19 PM
SS-ROB's Avatar
FMIC is very nice I promise you will like it!!!
Old Feb 11, 2009 | 04:53 PM
B.Buster's Avatar
Thanks Bob appreciate the help. LS1RedZ , where did you get that grill ? Took bumper and cover off and pulled dual IC system out today.Came out faster then it went in.
Old Feb 11, 2009 | 06:20 PM
Rickys S/C Z28's Avatar
you will love it man i have one in my 00 camaro and i have that same grill in mine you can get it on e bay for cheap
Old Feb 11, 2009 | 06:26 PM
B.Buster's Avatar
Where does intake air temp senser mount ?
Old Feb 12, 2009 | 12:15 PM
02NBMFormula's Avatar
look carefully in this pic and you should be able to see it. it is in the pipe before the maf
Old Feb 12, 2009 | 03:40 PM
LS1RedZ's Avatar
It was a polished grill.. I sanded it down and painted it flat black so it would bring out the FMIC more. Cant remember exactly where I got it.
Old Feb 12, 2009 | 05:24 PM
'Trust''s Avatar
Bob, will there need to be any change to an SD tune after installing this? Do you know where the brackets can be bought to keep the fog lights for a T/A? If IAT's are high on a twin 4.5" setup would you suggest this or meth at 17psi?
Old Feb 12, 2009 | 06:27 PM
B.Buster's Avatar
I see the senser. Looks like the stock harness will reach. Thanks.
Old Feb 13, 2009 | 09:10 PM
B.Buster's Avatar
I'm hoping it comes tomorrow , got the weekend off .
Old Feb 14, 2009 | 06:40 PM
B.Buster's Avatar
It came today and I started install. Should I remove the plastic wall that is between FMIC and radiator so the air flows though , trim it or bend it out of the way. Thanks Bob, it's nice kit.
Steve
Old Feb 14, 2009 | 07:07 PM
LS1RedZ's Avatar
I got rid of everything up front. Plastic, bumper support, and washer resevoir.
Old Feb 15, 2009 | 08:44 AM
EPP's Avatar
EPP
Steve
Whew! I'm glad it showed up! We generally remove the piece of plastic. Thanks! Bob
Old Feb 15, 2009 | 08:50 AM
EPP's Avatar
EPP
With an SD tune I doubt any changes would be necessary.
We made our own brackets for one T/A where we welded the foglights to the intercooler. We did not make a template for these brackets so we would not be able to make any bracketswithout having another T/A that we were installing our front mount intercooler on.
I would personally prefer to use a larger intercooler over methanol as the first line of defense against high inlet air temps. Bob
Old Mar 21, 2009 | 09:14 AM
EPP's Avatar
EPP
Do you have pictures of your front mount intercooler installed that you can post up? Thanks. Bob
