Octane and Boost (no meth)
Old Feb 11, 2009 | 12:19 AM
'Trust''s Avatar
Default Octane and Boost (no meth)
How much octane is good for how much boost? I.e 91 octane up to Xpsi, 93 octane up to Xpsi, and 101 octane up to Xpsi? What do you guys think? Any rule of thumb? No meth in the equation?
Old Feb 11, 2009 | 02:29 AM
ElectronSS's Avatar
ive ran 15psi with a PT88 no meth with 18* timing with AFR of 11.0 with no KR and only IATs 15* above ambiet. let it be noted it was 40* outside
Old Feb 11, 2009 | 07:02 AM
No Juice's Avatar
I'd say it would be tough to develop a rule of thumb. I've see both 93 and E85 up to and over 30psi making anywhere from 1200 to 1400rwhp. It all depends on the set up.
Old Feb 11, 2009 | 07:43 AM
ls1290's Avatar
Dumb Ass Vette Moderator
Way too much of a loaded question. There are just too many variables to say X octane with support Y psi. The possibility of talking about this is on a complete stock car and a specific make/model head unit.
Old Feb 11, 2009 | 11:23 AM
MIGHTYMOUSE's Avatar
better to equate octane to horsepower capability, but even then you have to consider cid strongly
Old Feb 11, 2009 | 11:27 AM
'Trust''s Avatar
Makes sense, so lets say the target is 700RWHP with a fair amount of drivetrain loss on my 9.5:1 396ci. No meth, what would the ideal octane be?
Old Feb 11, 2009 | 11:55 AM
CHRISPY's Avatar
Need to look at a few extra factors
1) static and dynamic compression
2) IAT and intercooler choice
3) timing
4) AF
5) Turbo or SCing
6) trans type and converter (if auto)
For example you can run easily 15#s boost or more on 8:1 comp with pump gas if things are setup right.
Old Feb 11, 2009 | 12:49 PM
2001-WS6's Avatar
The annual savings between fuels in the 91-93 octane range is pretty trival in terms of the overall hobby costs. You won't scrape by on 89 octane. So you run the highest that you can get on a regular basis and tune to it. Then you don't have to worry about what's in your tank when you hit the track.
Rick
Old Feb 11, 2009 | 01:02 PM
Photochop's Avatar
How about tuning the car on 101 octane pump from that shell on 63rd/western and not go WOT in it when putting around on the street on 91 oct? Do that and don't fool with meth...would that be a feasible option?
Old Feb 11, 2009 | 01:27 PM
jfg455's Avatar
so let me get this straight, You are telling me that you can roll around with the potetial of 700hp and not have the temptation to wack it just once? LOL! We all know that you will jump on it at least once and we all know it will detonate and kill itself in a matter of seconds. I for one do not have that kind of discipline! JMHO
Old Feb 11, 2009 | 02:21 PM
Photochop's Avatar
LOL, just a thought! As little as this guy drives this car - I'd just get it tuned on 101 and run it all the time. Either spend the money on 101 all the time or meth when you need it. Or tune on 91 and see if you can hit seven hunge. Or you could be like some of the import crowd and tune on a 'blend'...like half 91 and half 101...and run that all the time to save a lil dough, and when you're gonna be out at the track or out flogging on it when its really hot out, run straight 101 to be on the safe side.
Old Feb 11, 2009 | 03:25 PM
ls1290's Avatar
That is like playing Russian Roulette with 6 rounds in the chamber.
Old Feb 11, 2009 | 03:52 PM
Photochop's Avatar
Just tune it on 101 and be done with it.
Old Feb 11, 2009 | 04:56 PM
'Trust''s Avatar
Haha, well the real debate in my mind is between 93 and 101, but you have a good point, I RARELY drive it. 101 will be right around $104/tank from empty, which isn't bad, assuming 1 tank a month.
Old Feb 11, 2009 | 05:02 PM
'Trust''s Avatar
1) static and dynamic compression No, idea, it is a 9.5:1 motor
2) IAT and intercooler choice - 80*, twin 4.5"s
3) timing - 20*
4) AF - 11.0 - 11.2
5) Turbo or SCing - D1-SC
6) trans type and converter (if auto) - 4L60E w/PI 3200 triple disc
Was that any help?
Old Feb 16, 2009 | 12:20 PM
'Trust''s Avatar
Anyone have any idea on this, I don't know whether to tune on 93 or 101?
Old Feb 16, 2009 | 04:56 PM
93 cuz if you tune it for 110 it might blow up on 93
Old Feb 16, 2009 | 06:49 PM
chris.shea's Avatar
why not just use the same timing table as your 93 tune in your 110 tune and just up the boost. SD tuned and crank the boost when your tanks got the good stuff and keep 6-8 lbs on the low stuff. How fast do people really need to go on a daily basis anyways? I could live with 1 night a week on the 110
Old Feb 16, 2009 | 07:00 PM
extremetoy's Avatar
if im tuned for speed density @9 psi on 91 octane(whats around here) could i throw in 110 and upp the boost a couple lbs w/o touching the tune?
also... if im at 600hp on 91 at 9 psi and i put in a tank of 110 w/o upping the boost or messing w/ the tune will i feel a noticable performance difference (approx how much rwhp would i be looking at?)
thanks, Gary
Old Feb 16, 2009 | 07:54 PM
code4's Avatar
I've found that gas can be different between fill ups which is very unsafe when you are running on the ragged edge. I have pushed mine a little but it is usually at night when it's really cool out. i have found that 3rd gear in my t400 right when i shift is when it may start to knock. this is because of the load on the engine.
anyway i can run around 14 psi in good conditions on 91.
