Largest T6 Turbo for Stock Cubes
What's resonable spool time for street/strip A4 car with 3400 stall? 3000, 3500 or 4000 rpm?
Trying to choose a one turbo that will work on stock cubes and future upgraded motor 408ci.
What can be done to help spooling a turbo? Can the boost contoller be used in any way to help spool the turbo quicker?
I know.
https://ls1tech.com/forums/forced-in...ted-101mm.html
https://ls1tech.com/forums/forced-in...new-setup.html
How did he manage spooling 100mm turbo with stock ci motor?
The Ford guys have been doing it on 302's for a long time.
Is it ideal? No. Can it be made to work? Yes. Spool up will be slow unless the proper steps are taken. Boost controllers with CO2 systems to help keep the gate closed and such. Tunes up plays a big factor.
Being you are planning a bigger cube engine later that will make use of the bigger snail, screw it and slap a thumper on the 346. Play with it till your big cube motor is ready. Then have fun.
Problem is I've seen some 6-cylinder Japanese car with big turbo but it will never spool without a nitrous shot at the begining to spool the big turbo.
So, is 88 or 91mm T6 too big for stock cube LS1?
