Oil Scavenge pump noise possible solution
Old Feb 16, 2009 | 10:40 AM
aknovaman's Avatar
Question Oil Scavenge pump noise possible solution
Has anyone tried using a PWM (pulsewidth modulation) circuit to vary the speed of their scavenge pump instead of a resistor?
The circuit is pretty easy to build.
Works like a champ to vary the speed od DC motors like the ones in treadmills.
http://www.electronickits.com/kit/co...tor/ck1400.htm
These can handle up to 30Amps.
http://www.bakatronics.com/shop/item.aspx?itemid=581
These can handle up to 16Amps.
Thoughts?
Old Feb 16, 2009 | 12:17 PM
BadgeZ28's Avatar
I am curious how much oil is being circulated through a supercharger or turbo? My question centers around the idea that a pump might be running dry part of the time.
Old Feb 16, 2009 | 03:23 PM
ZL1Killa's Avatar
It may not necessarily be running dry, just slightly coated, lol.
Old Feb 16, 2009 | 03:53 PM
BadgeZ28's Avatar
I would love to see a bench demo of the flow rate of oil through the unit. I bet something like a quart sized sump setup would be a better return option. The pump kicks on and off by a level indicator.
Old Feb 17, 2009 | 06:51 PM
aknovaman's Avatar
If you PWM the pump you effectively/safely vary the speed and noise level.
