Mocal or Shurflo for my rear mount build??
Neither. I've had the mocal. They sound like hondas with fart cans in your trunk. The diaphragm is likely to break down in a year also. Check the shurflo because many of them are not rated for oil. Spend a little cash and get a good gear driven pump. Engine gear online sells reasonable ones.
the only reason i was looking at other pumps is i have seen many of the pumps supplied from sts fail and they are engine gear pumps.
Yeah mocals are loud but unless you have a dead quite exhaust you will hear it. The only time I hear mine is on start up thats it. As far as the sts pumps they are a good pump mine lasted 3 + years and just died. I think some people dont set the right current for them nor set how fast the pump needs to be.
Ive used flojets for years, but in the last year or so, they have taken a huge dive. Im only guessing that they changed somethng inthe pump so the failure rate is huge.
Now Im trying sureflo. Both are oil compatible, and actually I was able to find the sureflo for less $$ then what I was paying for the flojets.
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
PM sent.
