Why don't imports have to "bulletproof" their engines for turbos?
Unless your making a lot of power the stock parts will work fine. Most people just buy the expensive parts for insurance against their inability to tune it right. My stock junkyard 5.3L shortblock is going on 3 years now putting around 640hp to the wheels. Its tuned pretty conservatively and runs like a dream, I'd drive it anywhere and I dont see anything breaking on it. I would guess its at its limits for being in the safety margin though.
There is a lot of mis-information around here. Honda engines can take some serious abuse/power when boosted if the setup is right and the tune is right, even on stock sleeves and internals. I built a little civic hatch back in college that involved a b18b1 engine swap and a turbokit I built. The car was tuned via some software very similar to HPtuners for our cars. On stock internals and everything, the car took 10psi and 115mph trap speeds for 3yrs before it was sold. Now 115mph isn't that fast for us, but remember that engine made 140hp n/a. I doubled its hp and it still ran like a champ.
Next car after that was a Mitsu Evo. The car runs 19lbs from the factory, so the block/internals are already well equiped to make 500whp pretty reliably. Matter of fact, you never have to worry about the block as its iron. The fastest Evo's in the world run the stock block with forged internals.
I too have never understood V8 guys obsession with changing the stock crank(when your not going with a stroked setup). I have never even heard of a stock crank failing from too much power. Same situation with our stock blocks....I have never seen one fail from too much power. I have seen heads lift because of lack of a 6th bolt in combination with a ton of power/cylinder pressure, but I have never seen an aluminum block crack purely due to too much power. Yet the first thing you will ever hear out of anyone mouth on this forum is to ditch the stock crank for a forged unit because its "better" and to go with an iron block. I would do both if I was shooting for 1000whp+, otherwise, I am staying stock crank(if F/I) and block
tuning plays a large part in that, cooling comes in second. Well built motors. And most imports do go with forged internals once they start going past 10lbs boost. At least around here they do. Had my *** handed to me by a CRX the other day. Caught up with the kid and turns out he had almost 12k in motor work done, 450hp big *** turbo at like 14psi. Helps when the car weighs 2300lbs. Once you get a decent tune your not going to have problems with detonation and so on.
most imposts arnt putting out as much hp but the thing is that they also have lighter cars some time with awd. a 400whp sti or evo will run low 10s all day rarely does an evo break 1000 hp. a lot of turbo guys do build there motor for 350+ whp but most turbo kits only being your civic up to 250whp
if you are going to add boost, I would upgrade the internals of the engine. Boost can be addicting. I had a b16 which I threw forged internals in and it would handle 17-18 psi no problem. I do not know how many times I have seen someone turn up the boost with their boost controller and blow a head gasket or loose a rod.
7 Second Club
As far as imports not having to do engine work there is two classes....
Mitsubishi/Toyota that came turbo
and
Honda/Acura that didn't come turbo
The 2jz and 4g63 are both setup for turbos and have decent internals. Take your stock honda and throw 500rwhp to it and I bet it doesnt last very long.
and
#32
I don't fully understand why they can take more of a beating with 1/2 the cylinders. But here is a PRIME example. My bro's S R T-4. 628hp 558wtq UNCORRECTED! And that's at 4400 ft above sea level. Keep in mind this a STOCK bottom end car meaning stock pistons, rods, and crank, even all the bolts in the bottom end are stock. The car hasn't only been putting down high hp for a short time. Try WELL over a year, and many many pulls.
Here is the video- http://s53.photobucket.com/albums/g7...628HP557TQ.flv
#34
Making good power with these smaller motors is much less forgiving than what you guys are used to playing with as well. I see so many f-d up set-ups on this site that make decent power and the owners are happy. Put those same caliber parts on a 2L and it will most likely be a turd. There is no replacement for displacement, yet that displacement is a bandaid in many regards.
#35
I was reading the sticky on the true cost of forced induction, and I noticed a lot of thing I had to buy to basically strengthen my engine. Well I know 10 import guys that put turbochargers on their cars without doing anything else to their engine, and they work just fine. So why do WE have to upgrade so many parts to use a turbo instead of just slap one on like the import guys?
With that being said look at the power difference. There are more then a ton of guys that have run 500 wheel horse power LS1's and LS2's for a good bit of time with no engine problems. There is a lot in a good tune. Try finding a NA import guy that just added a turbo kit on his car and try to make 500 to the wheels on a stock engine. I think you will find very few.
#36
all i have to say is my ex roomate had a GSX eclispe and he was running a stock motor and pushing 22 psi on it. for me lt1 mostly stock except msd, exhaust, intake........ his car would keep up with me but i would smoke him after 2nd gear. i got better gas mpg and sounded much meaner. that was 3 years ago. his car blew a rod through the bottom after 7 months. as for me still running like a raped ape. go gm!!
#37
My nephew has thrown rods in 2 honda motors and is getting tired of it and now is thinking of getting a Firebird.I kept telling him he couldn't keep tring to juice up those little motors and live and it looks like he is finally going to believe me.
#38
lol.
FIRST OFF THE GSX IS A FACTORY TURBO CAR. Also AWD thats why he jumped on the start.
SECOND. 22 PSI on a turbo the size of your fist inst much that is why a lot of dsm guys swap out to the bigger 16G's (more power at a lower boost) At 22 PSI on a stock DSM you are just blowing hot air and are way above the turbos efficiency.
And finally 22 psi on even a well bolted and cooled 4G63 is a ticking time bomb on both 1st, 2nd gens.
#39
