turbo spool vs AFR & Timing
Old 02-22-2009, 12:15 PM
cablebandit's Avatar
3200-3300rpms
Old 02-23-2009, 10:08 PM
pmbmax's Avatar
Originally Posted by crashly
it has 3 rd rpm limiter, than can be controlled by electrical signal , to help spool the turbo before you go into full stage, AND will not activate the trans break , and stop the car from rolling into full stage...
go to msd web site amd down load the instructions...
Most people hook the 1st wire up to the foot brake. so bring it up to that limit prestage with foot brake and trans brake it goes to the second rev limit.(bump it on the t brake) pick your foot up and it goes to a third limit that will be the rpm you leave on . then it default to the high rev limit. Works good also if you are below your set point your shift light will be off when you are on the rpm it stays lit up and if you go over it will flash . This is one bad *** box .
Quick Reply: turbo spool vs AFR & Timing
