Kentucky Turbo Build!!!!!!!!!!!!!!!!!!!!!!!!!
Old Feb 23, 2009 | 10:47 PM
F-BodyGuy98's Avatar
looks like a good set up, i just wish i had found this set up beofre i bought the STS kit i have now...
Old Feb 23, 2009 | 11:27 PM
Rickys S/C Z28's Avatar
looks great man!!
Old Feb 23, 2009 | 11:43 PM
boydcoz71's Avatar
Looking good
Old Feb 28, 2009 | 05:58 PM
99CAMMEDSS's Avatar
SO i finally got a little something done with the car this weekend, finished the oil drain and feed line setup with the oil pan, the stock radiator and the pipe from the intercooler to the throttle body was way to tight, so i picked up a griffin radiator that you guys buy to put vertical but i decided to just let it sit like the stock style because i didnt want to cut up my car any more ha, also picked up a few other little things too. Pretty much now i just have to get the alternator relocation kit, fans, and a 3 bar map sensor if i decide to do speed density. Here are some pics of everything mocked up
Old Feb 28, 2009 | 09:15 PM
LilJayV10's Avatar
Oh I want a KYTP kit so bad..so bad....I wish I could decide one thing to spend my money on instead of half a dozen.
So you are NOT keeping the A/C? I missed that part.
Old Feb 28, 2009 | 09:40 PM
trnsfmr99's Avatar
I'm purchasing my kit monday!!! Can't wait!!! We have almost identical camaro's and yours looks great!!! Congrats and i'll be paying attention. What kind of front grille will you go with?
Old Feb 28, 2009 | 09:48 PM
99CAMMEDSS's Avatar
Ya this particular kit does away with the a/c.
Old Feb 28, 2009 | 09:50 PM
99CAMMEDSS's Avatar
Thanks man, im not really sure on the grille yet but maybe thinking about painting one of those billet grills on ebay but not really sure ill probably decide after im done with everything.
Old Feb 28, 2009 | 10:03 PM
black98ws6ta's Avatar
I think your center section is probably at too much of an angle to gravity drain right. I think they reccomend to keep the angle under 30*at worst.
Old Mar 1, 2009 | 02:31 AM
98Camarod's Avatar
If you get a 3 bar map, you have to have a 3 bar tune. Keep that in mind. Build looks good
Old Mar 1, 2009 | 05:02 AM
LilJayV10's Avatar
What manifolds does your kit use?
I talked to Josh about doing a C6/truck manifold setup that will let me keep my A/C and P/S. It uses a tubular k member but that isn't a big deal and I don't have to space out my sway bar.
I have thought about having all the hot side coated/wrapped to help keep under hood temps down and spool time.
Is that what you are going to do?
Old Mar 1, 2009 | 07:49 AM
  #32
99CAMMEDSS's Avatar
Thanks for telling me i wouldn't have known, cant i just loosen the bolts on the turbo and rotate the center section to the right angle or would that be wrong?
Old Mar 1, 2009 | 07:51 AM
  #33
99CAMMEDSS's Avatar
Ya ill defiantly keep that in mind i just cant decide between mass air or speed density.
Old Mar 1, 2009 | 07:54 AM
  #34
99CAMMEDSS's Avatar
I am using the truck manifolds for my build, and on the exhaust side of the kit im kinda going the cheap way out and just painting everything with high heat header paint and wrapping all of it with header wrap, im hoping it will hold up but i dont drive the car in the rain or nothing like that.
Old Mar 1, 2009 | 08:30 AM
  #35
DrTurbo's Avatar
LS1TECH Sponsor
Man that is coming along nicely. Josh and KYTP really do make a nice drop in kit. When do you anticipate having it on the road.
Old Mar 1, 2009 | 02:31 PM
  #36
Sandmann120's Avatar
Kit looks great. Keep the pics coming.
Old Mar 8, 2009 | 05:11 PM
  #37
99CAMMEDSS's Avatar
Alright i got alittle bit done this weekend i painted and wraped all the hot parts, made brackets for the radiator, mounted the fans, dropped the pipe that goes to the TB off to get a bung welded for IAT sensor, modifed and bought some different radiator hoses, the only things left to do is bolt the cold side up, get a alternator relocation kit, 2-bar map sensor, and thats about it so i am very close to getting done
What do you guys think of the pipe that connects the upper radiator hose, i just ran the little line from the heads, do you think it will be fine or work that way? I just needed the other nipple on the radiator for the overflow.
Also do yall think the drain line for the turbo will work good or should i re-arrange it?
Old Mar 8, 2009 | 05:15 PM
  #38
99CAMMEDSS's Avatar
One more question what do yall think of were the wastegate points do yall think it will get anything to hot or do i need to do some kind of dump tube?
Old Mar 8, 2009 | 05:21 PM
  #39
Caspernicus's Avatar
I'd flip it around and put a dump pipe on it.
Old Mar 8, 2009 | 05:37 PM
  #40
Josh@KY-Turbo's Avatar
Measure the distance from the WG flange to the othe side of the charge pipe. I will make you a Dump tube if you want.
