Kentucky Turbo Build!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 28, 2009 | 03:55 PM
  #61
99CAMMEDSS's Avatar
So i finally got the exhaust ran and i just have a few questions on deciding on a muffler, the only muffler i have tried so far is the moroso spiral flow race muffler and it quitened it down pretty good and sounds decent but i am just wonder if the spiral flow design is no good for a turbo car and was just wondering how it would compare to like a dynomax bullet of some kind?
Here are some pics of the design..
Old Mar 28, 2009 | 07:30 PM
  #62
99CAMMEDSS's Avatar
NVM i just got a bullet on there instead of the spiral.
Old Apr 27, 2009 | 09:09 PM
  #63
99CAMMEDSS's Avatar
Finally i got the car pretty much finished i just have to go get it tuned and dynoed, after a month on waiting on fenix999 to send me the alternator relocation kit i gave up and ordered the speed inc relocation kit which seems to be a really nice kit and works good but now the dam water gauge is all screwy and i cant figure out whats wrong with it, i have replaced the sensor twice but i guess its something else, sometimes it wont work at all and other times it fluctuates up and down and the cars rpm will fluctuate too and sometimes die, soo im pretty much stumped and was wondering if anybody has any ideas????
Old Apr 28, 2009 | 06:16 AM
  #64
98Camarod's Avatar
If everything fluctuates, I'd say its a ground issue. Another question for you, did you disconnect the battery when you were welding?
Old Apr 28, 2009 | 08:13 PM
  #65
99CAMMEDSS's Avatar
So i drove the car around today and dang does it feel good to drive it again, everything seems to be good to go, hopefully i can try to get it scheduled to get tuned and dynoed at Atlanta performance fabrications. Here are the complete pics with the exhaust, cut out the front bumper and the speed inc alternator relocation kit, ill def try to get dyno videos.
Old Apr 28, 2009 | 08:14 PM
  #66
99CAMMEDSS's Avatar
thanks for the reply but it looks like i got it fixed today, the plug for the temp sensor was worn out so i just bent the little pins inside it to make a better connection
Old Apr 28, 2009 | 08:30 PM
  #67
waterbug1999's Avatar
Nice build.... It was reading 16#'s of boost at the track? Did you get that fixed?
Old May 20, 2010 | 08:59 PM
  #68
calgaryls1's Avatar
I am ***** deep into my kit right now just trying to bolt up the 6.0L manifolds. drivers side will work but did you have any clearance issues on the passenger side there is no way it will fit my car without subframe mod
If that link works that stud crushes the line when it is even half screwed in :S
Old May 20, 2010 | 10:14 PM
  #69
98Z28CobraKiller's Avatar
Restricted User
I only see a red X. It should fit without any modification. You sure you're using the right manifolds.
