Spraying the Intercooler
To the OP, it would be cheaper and more effective to spray a water or water/alcohol (not meth, too corrosive) mist on the front of the IC during the run. Just watch out at the track - they don't like fluids dripping from your car on the line... a Hobbs switch would be easy to wire in so it turned on at a certain boost point.
Jim
Jim
A Nitrous spray bar will lower your IATs when spraying on the intercooler. You have the line, the solenoid, and the bottle. Build aspray bar and be done with it. And, Nitrous goes from a liquid to a gas and will not leave puddles on the track.
If you must use gas, consider a simple CO2 bottle, since filling it is way cheaper than nitrous.
I have enough ghosts - don't need another
Jim
has a button he can press in prestaging for 6- 8 secs to freeze everything up , then it operates on a full throttle microswitich .....quite trick.
Jim
Cheers
Chris.
Find the cheapest non-flamable gas that that can be easily obtained at high pressure and use that if you want to pursue this concept.
I did not want to richen/cool the mixture with meth/alky because I wanted things as simple as possible. (I don't want an additional pump/piece that could fail)
With the spray bar, if the solenoid stick open or close, no big deal.
I am sure when I turn up the boost meth/alky will be a consideration.
But I really hate to add more components. (KISS principle)
