More boost for ninetres????
Old Feb 27, 2009 | 11:43 PM
2001-WS6's Avatar
Originally Posted by ninetres
Tell me about your set-up. Cubes, CR, PSI at manifold? Front or Rear mount? Race weight? And best ET/Trap speed?
I gotta believe I could squeak a bottom 9 outta 16 psi.
It's the TTI race kit with a 3.5" DP. The engine is a forged 402ci at 8.7:1 cr and unmodiffied mototron 60 injectors. ST80 1.1A/R with the race cover. T400 trans launching off the brake. The car is about 3,700lbs and it runs a 1.43 60' for 9.4s at 148mph with 94octane and meth. Stock front wheels and drag radials out back.
The 4" DP will definitely help you out with the back pressure issues. The turbo is really just starting to wake up at 16psi and you'll do pretty well with it.
Rick
Old Feb 28, 2009 | 12:10 AM
ninetres's Avatar
Rick
Sweet. Our cars a VERY close in weight. I think the 4" DP and 32 less cubes than you will help out with the back pressure at least a tad. I have 96lb injectors FWIW......way more injector than I anticipate needing on a 4 bolt set-up. My car also is a bottom 1.4x 60 footer on its best passes so far. I'd REALLY like to shave that down to a 1.30 this season. At the end of last season I finally found a tire my car liked and I only got about 6 passes on them. I'm sure with some more suspension tuning I can cut my 60' down.
Old Feb 28, 2009 | 12:15 AM
VENGEANCE's Avatar
ohhhhhhhhhh shitson! good luck with your goals.
