My new spool assist and launch weapon!
Old Feb 26, 2009 | 08:28 AM
veee8's Avatar
Default My new spool assist and launch weapon!
I got the transmission finished up, just waiting on a few more items to arrive, so I can go back and really assault the quarter mile.
Specs on the trans....
TH400 1990 core with electronic speedo.
Fully blueprinted
JW Ultra-Bell
Griner 34G10 Billet transbrake, reverse manual, with reverse safety
Hipster's HD direct spring kit
Griner TH400 adjustable pump pressure regulator set to 225 psi line pressure
4L80E Intermediate drum
34 element sprag
4L80E Borg Warner High Energy friction and steels
6 clutches in forward and direct, 4 clutches in intermediate
Special "top secret" modification to the direct drum
Filled case for better fluid flow for high hp cars
Drilled and tapped for 7-bolt pump
RCI blanket
TCI flexplate
Custom PTC turbo converter
So I should be able to build boost and launch like a **** now.
Here is the Cheetah shifter...
And here is 1 piece of the rearend puzzle, the Moser 35 spline gun drilled and star flanged axle shafts arrived, still waiting on the rest of the rear from Midwest Chassis.
Old Feb 26, 2009 | 08:36 AM
hellbents10's Avatar
LS1Tech Sponsor
Cool, its going to be track warrior now!
Old Feb 26, 2009 | 08:58 AM
onfire's Avatar
Coal Mining Director
Before you install it, put an overflow line in the vent port and take it to a bottle...that will save a big oil mess on your trans blanket when you building boost on the line.
Old Feb 26, 2009 | 09:16 AM
HUNTER02SS's Avatar
You will love the PTC Converter.They do alot of R&D on there turbo converter's. I love mine!
Old Feb 26, 2009 | 09:19 AM
Fireball's Avatar
why did you go t400 instead of a glide?
Old Feb 26, 2009 | 09:22 AM
HUNTER02SS's Avatar
ALSO, you have to make a modification on your bellhousing to make it bolt up flush to the motor. If you look at the plate on the back of the motor there is 4 bolts on the top, 2 on the left and 2 on the right. Either grind those bolt heads down or you have to ake out some material on the bellhousing. Also since the bellhousing is much thicker than a stock case you will have to shim the converter toward the tranny a little. If not the converter will pull out of the tranny to far and you won't have much engagement to the pump. I used some head stud washers since they are hardened steel.
Old Feb 26, 2009 | 09:24 AM
veee8's Avatar
Yup, we removed the stock vent line, and tapped it for a fitting. I am building an overflow tank.
Old Feb 26, 2009 | 09:26 AM
veee8's Avatar
I tried the converter a couple of weeks ago before I pulled the trans back out. It seemed to work great, it is nice and tight, exactly what I wanted. It was built for the transbrake.
Old Feb 26, 2009 | 09:30 AM
veee8's Avatar
I had the 400, and wanted to see how it does. I don't have a ton of money is it. If the car ends up needing a glide, I will have to step up and get something like you have, but for now, I am going to try the 3 speed. The goal is to max out the cert on the cage, 8.50's. At that point , I will have to re-evaluate the car, and see what direction to go.
Old Feb 26, 2009 | 09:32 AM
Fireball's Avatar
Gotcha...was more curious than anything...expecially since the deeper 1.80 first gear is supposed to help with spoolup after launch
too bad that bellhousing doesn't have a provision for the top bolt on the ls1
veee8's Avatar
Yup, I anticipated that, I mocked up the bell on the car before I installed it on the trans. I milled the 4 bolts down to get the clearance. I had to dimple the floorpan a touch, just to get it up to the engine. That thing is girthy!
Old Feb 26, 2009 | 09:33 AM
veee8's Avatar
I choose a 3.00 gear for the 9" to help with that.
I know,I was hoping they would have gotten out of the dark ages and just added it, but of course not.
Old Feb 26, 2009 | 04:10 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Looks good to me. That converter will make a big difference over the one you had in there.
Old Feb 26, 2009 | 07:56 PM
Silver_TransAm's Avatar
Looking good. I cant wait to see it tear up the track.
Old Feb 26, 2009 | 10:08 PM
98turbls1's Avatar
Looks a lot like mine... It is very docile around the street but watch out once you get into it.
Old Feb 27, 2009 | 07:09 AM
veee8's Avatar
I am expecting the dyno numbers to go up a bunch too with the PTC converter. The TCI was hitting like 36% slip!!!!
This new one is tight.
Old Feb 27, 2009 | 09:52 AM
turbo'd stang's Avatar
That all sounds like it should work out really well for you. I like your choice of gearing!
Old Mar 3, 2009 | 08:20 AM
veee8's Avatar
Got my new driveshaft today. It is a Strange chrome moly 3" with upgraded chrome moly trans yoke. This thing is lighter then the 2.75" Spicer steel custom shaft I had.
The rearend package is supposed to ship out today. I can't wait!!!
