F1 procharger on a stock block
Old 03-02-2009, 05:09 PM
'Trust''s Avatar
Originally Posted by black01_WS6
What size CI are most of the F series blowers running? Just trying to see if the F1 could be in my future or not. I was going thru the same question as the OP.
Depends, F1-C's are designed for smaller cube motors, so from (LSX only) 346 to whatever. Most F1's you'll see will be on 402ci + though.
Old 03-02-2009, 05:54 PM
black01_WS6's Avatar
Thats what I was thinking/ have been told. I am just thinking of picking up a F-1 now and building the motor over the next year. Do the F-1's mess with the AC at all. I wouldn't think so.
Old 03-02-2009, 06:03 PM
'Trust''s Avatar
I don't believe so, ChevyChad has a F1 on his f-bod, may wanna ask him or Bob at EPP for a finite answer.
Old 03-03-2009, 04:39 AM
EPP
EPP's Avatar
AC is just fine with an F-1A, but on some cars the bottom of the radiator needs to be moved forward slightly. Bob
Old 03-03-2009, 08:03 PM
Thanks Bob- I am going to be up your way this summer for a week or two. Might just see what kind of deal we can put together. Only problem is the car will still be in Florida, but I will have my truck up there.
Old 03-03-2009, 08:25 PM
01turdbird's Avatar
Is there a sponsor on here that will make custom pullies for that f1
Old 03-04-2009, 04:48 AM
EPP
EPP's Avatar
We can get them made for you. Give us a call at 260 244-4808 and we'll check on pricing for you. Thanks. Bob
Old 03-04-2009, 04:49 AM
EPP
EPP's Avatar
Thumbs up
Sounds good Mike, see you this Summer. Bob
Old 03-04-2009, 09:02 PM
charged 434's Avatar
I am installing the same thing in my ls1. stock bottom end , changed the head gaskets to 90thous. and head studs, ported heads, changed to victor junior, 60# inj. kooks headers, fluiddyne rad. and cam putting f1c on the baby. just installed it today actually. i will run a 5 " pulley. but running meth also hope it will last several months build a 434 after that
Old 03-06-2009, 10:22 AM
EPP
EPP's Avatar
Update from ProCharger:
http://www.exoticperformanceplus.com....html?item=970
8 rib pulley sizes up through 5.25 are available! Bob
Old 03-06-2009, 08:27 PM
Bob what kind of boost are you seeing with the 5.25? I think I have made my mind up.
Quick Reply: F1 procharger on a stock block
