Vortech X-Trim on my 436 stroker........................
Old Oct 16, 2003 | 02:48 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Vortech X-Trim on my 436 stroker........................
Get me his email address, ls1.com has a bunch of us blocked from there.
I will call BS, the Xtrim is HUGE.
Old Oct 16, 2003 | 06:14 PM
stealth's Avatar
YSI trim is rated at ~1700 cfm, +/-, give or take.
I just returned a X-trim mockup to Vortech last week.
PSJ, regarding LS1.com blocking you, have you not learned to play well with others?
Old Oct 16, 2003 | 07:22 PM
Quickin's Avatar
Will an X-Trim fit on an F-Body?
Do you think 1,000 RWHP is possible with either the X-Trim or the upgraded YS-Trim on say: a 427 iron block with C5R heads and a sheetmetal intake. Built with the best parts available like you mentioned. 4L80E tranny and a built Ford 9" rear-end.
Project "WS6sc1000" is brewing in my head.
Old Oct 16, 2003 | 07:52 PM
JimmyKash's Avatar
PSJ, if that guy would fit a F1R blower, you could fit an X-trim. It will just be difficult
Old Oct 16, 2003 | 08:42 PM
stealth's Avatar
As I said, we tried to fit an X-trim into a 2001 SS last week but couldn't find a spot. It would probably fit under a bubble type hood if you can lower the engine like ours.
I'll be better able to tell you in a few weeks whether an X would make 1000 rwhp with your setup, but it probably would. I would drop the 80E idea in favor of a T350 or 400.
Old Oct 17, 2003 | 12:18 AM
Quickin's Avatar
The 80E is a 400, just with computer controlling.
Would a non-computer 400 with GearVendors OD work perfectly?
Or would you have to up shift and down shift manually?
Old Oct 17, 2003 | 01:43 AM
JimmyKash's Avatar
sorta.....they are not identical though. The case is bigger and they are much heavier. Plus torque converter selection i think is very big (yet)
Old Oct 18, 2003 | 06:15 AM
strife's Avatar
V4 XXX trim that went on a local C5R HSV, ended up swapping it out for a F3-R
Old Oct 18, 2003 | 10:50 AM
Quickin's Avatar
Do you mean a Vortech X-Trim went on it first? What RWHP did it get? What ci was the motor?
How did it do with the F3-R?
