Stupid FI + EVAP question
Old Mar 4, 2009 | 04:10 PM
Gauge's Avatar
11Second Club
Default Stupid FI + EVAP question
Hey all,
I don't know why I was just thinking about this, but should a FI setup always delete the evap line? Doesn't the boost go back into the tank through the evap line? If so, isn't that an issue?
Old Mar 4, 2009 | 04:37 PM
Black01M6SS's Avatar
What evap line?
The evap line is connected to a computer controlled solenoid that only opens when conditions are correct similar to the EGR system. I don't know for sure what the correct conditions are for the valve to open but I have never heard of anyone having an issue with the evap system and boost. The base Vortech and Procharger systems are emissions legal so I assume they do not effect the evap system.
Old Mar 4, 2009 | 06:12 PM
Gauge's Avatar
11Second Club
Thanks for the input.
Old Mar 4, 2009 | 06:42 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Mine fell off a while ago and got stepped on..... repeatedly
Old Mar 4, 2009 | 07:16 PM
Silver_TransAm's Avatar
What do you do if you go to the vic jr. setup and there is no provision for it? I mean right now its there but it is not hooked up to the intake anymore. Will venting it to atmosphere matter? what do I do with it?
Old Mar 4, 2009 | 07:42 PM
Well, if you want to keep the system you could connect it anywhere you have vacuum on the intake. I think most people just do away with the whole system. If you vent it to atmosphere you might smell some gas fumes but other than that I don't think it will give you any problems. Mine is just disconnected at the tank. It is not a bad idea to keep the system though. It doesn't hurt anything other than the looks of the engine.
Old Mar 4, 2009 | 08:07 PM
cool thanks, I will just get rid of it then. Just taking up space.
Old Mar 5, 2009 | 12:19 AM
eviltwin_1987's Avatar
i took mine off and drilled and tapped the one for my intake temp sensor. turned out really nice
Old Mar 5, 2009 | 01:56 PM
bboyferal's Avatar
I prefer the smell of gas... Not a problem...
Old Mar 5, 2009 | 01:57 PM
candlelit's Avatar
after that you probably done a burnout on it too
Old Mar 5, 2009 | 02:11 PM
ChevyChad's Avatar
8 sec potential, 12 sec slip
