any pict.of procharger mounted on ls1
Old Mar 4, 2009 | 08:19 PM
charged 434's Avatar
Default any pict.of procharger mounted on ls1
I jusrt mounted f1-c on my 99 ls1. just wondering if any one has any pict of theres mounted. it looks mighty close to the altenater pulley. i had to order the studs and stand offs, the guy i bought it from left them out so just wondering if it is correct. i only have about an 1/8th inch between the two. this is an 8 rib setup thanks
Old Mar 4, 2009 | 09:17 PM
9t8z28's Avatar
Yes, it sits very close. Make sure the pulleys are lined up
Old Mar 4, 2009 | 09:21 PM
9t8z28's Avatar
[IMG][/IMG]
Old Mar 5, 2009 | 07:01 AM
thanks i see that you have a nut on the end of the extenders at the top mine doesn't have that so you could imagine how close it is. and the other thing is the radiator lol oh well get out the plasma cutter thanks for the pict
Old Mar 5, 2009 | 11:09 AM
MadIceV8's Avatar
Customizing Director
I have the standoffs but am in need of the studs/rods. Where do you get yours from? Thanks.
Old Mar 5, 2009 | 11:50 AM
9t8z28's Avatar
You can get them from Procharger or EPP probably has them as well
Old Mar 6, 2009 | 06:42 AM
yes i ordered them from procharger. i got all the nuts and bolts to mount it to the bracket, studs, everything for $55
Old Mar 6, 2009 | 07:32 AM
BLNLS1/RX7's Avatar
You need to contact Bob at www.Exotic Performance Plus.com. He has a lot of pictures and he can help you out.
