My 2009 Build for my Turbo 98 Cyber Gray SS with pictures
OWN3D BY MY PROF!
I love the radiator setup. I'm building a baby version of this with my 93. I'm not sure on how it sizes, but my new turbo is coming and from what I gather it is right around the same physical size as the 106. Did you choose to run a remote water pump because of the DP or was there another reason? Could you take some pictures of the water pump for me? I think it is right under the passenger side of the cross over, but it's hard to tell how it is mounted, etc...
EDIT: I also like how the rear metal was redone to make the water tank and fuel cell mount flush in with it. That's a very nice touch.
Water pump: a little better flow, and room
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
My builder is all about class, something no one else has done, and reliability
David
#37
Thanks guys.
The value covers, tanks, cold side piping are all powder coated - wrinkle black.
I'll get some better pictures of the lines from the valve cover to the tank when finished.
The carbon fiber inserts are custom made for me by a friend here in Sioux Falls. To my knowledge a one off insert - want one?
David
David
#39
David,
I can't get the pics to pull up from where i am at right now, but would you mind commenting on your DP exiting location? I have a DP ready for my setup(also 5" and exiting in front of front passenger tire).
I have been told by a few that this could pose as a legality problem in some races/events. Was this a concern for you?
#40
David,
The exhaust exits just in front of the passenger side tire.
There is a lot of races that do not allow this type of exhaust. BUT I'm in South Dakota and will not be racing in any of the big races. Maybe - big maybe - the LSX race this fall, but we can change the exhaust if we have to.
Good luck on your build.
THANKS to everyone on the great comments. We didn't finish the SS, but are going to still take it to the World of Wheels show in Omaha NE this weekend.
David
