TTI 70MM Street Build!!!!
Im useing a stock cobalt sensor, suppossd to be plug and play.
i think its time for me to cruise over to the pcm and tuning department for a couple days lol.
keeps A/C
Stock K member.
Extremely bolt on friendly!
did have to shim drivers mount with a 3/16 washer to clear steering and bend the stock power steering lines.
problem is, anything past quarter throttle and it goes 10:1 rich and bogs out, but if you slooooowly lean into it its comes up fine. probably ve because its part throttle fueling right? pe hasnt even kicked in.
Still ...made 430 rwhp
TONS of threads on going from the wide band to the egr but not the Innovate module to the egr
and the hp tq numbers shown in my sig were only at a correct 7.3psi...
got that fixed haha.
