which fuel pump?
Old Mar 12, 2009 | 11:29 PM
Flaco's Avatar
Default which fuel pump?
which fuel pump are you guys using when over 1200-1500 hp using..
i currently have an a-1000 but am going forced induction now and i know it is not going to be enough for the new plans.. so need to change it out
any suggestions for that amount of power?
Old Mar 12, 2009 | 11:47 PM
Inspector12's Avatar
TT-TECH Veteran
I like the Weldon 2345-A rated at 2000hp leaves you a little room to play with although the 2035-a would work and is cheaper rated at 1800hp Flaco.
Jeff
Old Mar 13, 2009 | 12:00 AM
Flaco's Avatar
i will look into them, thanks
Old Mar 13, 2009 | 06:34 AM
Shawn @ VA Speed's Avatar
Weldon is the only way to go.
