T76 feeding a TVS1900 blower
Chris.
Well, It's together and RUNNING!
still have a bunch of tuning to do, don't have the intercooler pump hooked up or coolant in it yet, but had to take it for a drive today. Needs a LOT of tuning, as it's way lean, which is a good thing right? The TB adapter didn't end up working, so I had to break down and by a Edelbrock 90mm TB. That in it's self was a pain, as I had to redo my throttle cable bracket and cold pipe as well as get another silicone adapter cuz it has a 4 1/2 inlet. I really think I'm gonna need to put a lot bigger turbo on it to really see the benefit of it though. I think I'm gonna have a little boost creep with this little turbo and 38mm WG. I have a 50mm WG, I can put on it shortly, but I'm thinking I'm gonna need a PT88 if I can find one cheap, since I have no idea when MP's 88 is gonna be done. Soon as I get the TVS intercooler finished up and the tune a lot better, I'll see if I can a vid made.
Here is the pics
and that's another option too...
Cost wise and airflow wise 2 of them are about the same as a new PT88, but a LOT more fabrication work. Would be cool though
Drove it a little more last night and still needs a lot of tuning, but it goes strait to 10 PSI with only a 3.3 pulley on the blower with NO lag.
I dont know why you would want it to come on so quick anyways, it isnt like it could hook well enough to use a good turbo only set up anyways. If you make to much down low, esspecially in a truck, all that power and money is just gonna be tire smoke in the end.
And I actually have a compound truck.........deisel ofcourse.
I don't know why you would want it to come on so quick anyways, it isnt like it could hook well enough to use a good turbo only set up anyways. If you make to much down low, esspecially in a truck, all that power and money is just gonna be tire smoke in the end.
Traction is not a problem, that's what the 4x4 button to the left of the steering wheel is for
. Sitting at stop light on the 2 step to build boost is not very sneaky, now stomping it from an idle and handing the Corvette next to me his ***, that what it's all about!
. No way you could get a turbo only setup to spool the way this thing is now.
.... and here i am dreaming of a measly 1 FI method (a supercharger), and you show up rocking compound boost! I am jealous, in a good way.
Every one said this would do nothing but make heat, and I don't even have water in the blower intercooler yet and the most I've seen for IATs with 10 psi of boost is 125* and it was in the 60's here today... Just think how it will be with having a functional intercooler I can put Ice in...
Keep us posted!
Chris.
PS how much boost is the blower alone making? it would be nice to see some logs for presure before the SC. then you could compare to a 'similar' turbop only setup to see just how much difference the SC is making.
