turbo piping
Old Mar 17, 2009 | 09:12 AM
importkiller_SS's Avatar
Default turbo piping
where does everyone get their Miscellaneous bends for a custom DIY build for the hot side of the turbo and cold side? low budget also
Old Mar 17, 2009 | 09:41 AM
Tricked-Out-Toy's Avatar
Summit for the hot side and Ebay for the cold side. you can ussually get a cold side for about $75 that will work. look for cold side kits that have T-bolts instead of hose clamps they are ussually a little better quality.
Old Mar 17, 2009 | 09:44 AM
Fireball's Avatar
depends on what you need...
I bought the stainless for my headers from one place,
the parts for my downpipe (stainless) and charge pipe (aluminum) from a different place since I needed tight radius bends....
Old Mar 17, 2009 | 10:03 AM
thanks i'll check out summit and ebay,
can you use something like Mild steel for piping?
Old Mar 17, 2009 | 10:07 AM
Sure its heavier than aluminum but it works just fine.
Old Mar 17, 2009 | 12:24 PM
matt_paco2010's Avatar
remember to use stainless or aluminium for the cold piping. Mild steel can rust and that's bad news for your motor.
Old Mar 17, 2009 | 01:31 PM
good reminder... i would have proplably used MS
thanks
Old Mar 17, 2009 | 02:01 PM
stangeater01's Avatar
is there a benifit for using stainless as opposed to aluminium and vise versa?
i was going to do all stainless
Old Mar 17, 2009 | 02:02 PM
aluminum is much better. Its lighter and its a better heat transfer medium.
