Boost reference FPR base pressure
Old Mar 17, 2009 | 07:09 PM
98Camarod's Avatar
Default Boost reference FPR base pressure
What is everyone's suggested base pressure? Right now, I have mine set at the stock pressure, 58 psi.
I'm in the beginning stages of tuning, I'm thinking that I may be screwin myself. Just want to make sure that I'll be alright if I decide to run any decent amount of boost.
Old Mar 17, 2009 | 08:22 PM
OUTLAWZ RACING's Avatar
Im far from a tuner and my fuel system may be way different but my rail pressure is set at 50 psi at Idle. I run a twin intank seprate feed setup.
Old Mar 17, 2009 | 11:02 PM
DarkFormula's Avatar
59psi. Dual in-tank Walbros with a return system.
Old Mar 17, 2009 | 11:05 PM
cablebandit's Avatar
39#with 96#injectors
Old Mar 18, 2009 | 06:52 AM
theblur98ss's Avatar
Mine is apx 40lbs also with 96lb injectors and dual bosch 420L pumps
Old Mar 18, 2009 | 07:18 AM
veee8's Avatar
30 psi base with triple 255 Walbro pumps and 160 injectors.
Old Mar 18, 2009 | 06:43 PM
98Camarod's Avatar
What kind of boost are you running and what pressures do you see in boost?
Old Mar 18, 2009 | 07:35 PM
cjg454ss's Avatar
i run a 60 base. twin walbros, 60lbs injectors.
Old Mar 19, 2009 | 01:13 AM
mterveen's Avatar
58 base at 0 vacuum/boost (i.e. fpr vacuum line not hooked up), lonnies twin setup, 60lbs injectors return system
Last edited by mterveen; Mar 19, 2009 at 12:08 PM. Reason: referenced to 0 vacuum/boost
Old Mar 19, 2009 | 09:40 AM
60-63ish on 14 psi 18 psi its 65 afr 10:7
Old Mar 19, 2009 | 10:32 AM
ChevyChad's Avatar
8 sec potential, 12 sec slip
mine is set to 58psi at 0 vac/boost with 60# injectors and dual intank 255 walbros. -8 feed and -6 return..
Old Mar 19, 2009 | 12:00 PM
SilverSS's Avatar
58psi. Are you guys referencing with vacuum and boost or boost only???
Old Mar 19, 2009 | 12:08 PM
cjg454ss's Avatar
im setting with no line on the reg. then let it go where it wants
Old Mar 19, 2009 | 12:56 PM
SD99TA214's Avatar
58psi at idle with 60#s and a single 255lph in tank.
Old Mar 19, 2009 | 11:01 PM
1point3liter's Avatar
40 base with a 1:1 regulator and 96# injectors
Old Mar 20, 2009 | 09:16 AM
stevieturbo's Avatar
Use whatever pressure is required, and your system is capable of handling.
Old Mar 20, 2009 | 09:22 AM
ddnspider's Avatar
~60 base+boost referenced.60# injectors.
Old Mar 20, 2009 | 03:53 PM
98Camarod's Avatar
What does your fueling consist of?
Old Mar 20, 2009 | 04:19 PM
ddnspider's Avatar
.5 inch hardline/8an feed using stock feed as return,speed inc rails,dual intank pumps
