APS 346 dyno 599/543
"1.606rwhp -640trq - 7.6 psi. 91 pump gas"
Now very similar but why is the torque so much higher.Would there be that much more torque from the bigger cubes or does some come also from the afr heads? Not sure how similar the cams are.
Lingenfelter GT7 208/230 .554/.546 –121CL
I run 1.8s so have more like 590 lift and bit more duration.Not sure what that means for powerband or torque as said haven't dynoed yet.
And not trying to diss the numbers I think 600rwhp is fantastic for pretty low boost on a 346 with just a cam. assuming stock heads?
Also heard timing can make a huge difference in torque and the car above was running alc injection so maybe that also acounts for big difference in torque.
secondly , i know that i am asking to much but what are your cam specs if you dont mined sharing
thanks
I am running stock heads and 91 pump gas and this was done with a maf tune. The cam specs are as follows 232/240 .595/.608 115
208/230 that is alot.
tony fomr afr told me to run a 228/228 on a 115.
i was thinking of selling it and getting somthing mor elike the LS9 cam but idk
