Track results are in!!!!!
Old Apr 8, 2009 | 09:27 AM
  #101
fitz98ta's Avatar
Congrats on the good times so far man. Also glad to see those LS9 gaskets holding. Can't wait to see it back out once the tranny is fixed.
Old Apr 8, 2009 | 10:01 AM
  #102
veee8's Avatar
Originally Posted by Fireball
why only 2psi? having spool issues?
This race was on a pro tree, still getting used to launching the car. The difference between half a second on the 2 step is amazing on how much boost it builds, once it crests 5 psi, it is instantly to 9 psi. I backed it down to insure I made a clean pass.
probably was on a low 9.40 run
I was figuring that, which is encouraging with the low 12 psi boost level.
Old Apr 8, 2009 | 10:03 AM
  #103
Fireball's Avatar
Do you have a 3 step or just a two step? 3 steps are awsome...build boost on footbrake in prestage...bump in and set 2 step to add a few more psi...
This year, I'm at 6psi in prestage and 9.1 psi at launch...I haven't adjusted anything yet...this was only 4 runs...
Old Apr 8, 2009 | 10:14 AM
  #104
veee8's Avatar
Just 2 step for now, I plan on sending the ECM back to John to have the 3-step and other little magic trick done to it.
Old Apr 8, 2009 | 10:28 AM
  #105
Fireball's Avatar
sounds like a winner
what other magic trick were you thinking about
Old Apr 8, 2009 | 08:11 PM
  #106
382ssz28's Avatar
Kiss and tell?
Old Apr 18, 2009 | 11:36 PM
  #107
turbociv910's Avatar
updates?!?
Old Apr 18, 2009 | 11:50 PM
  #108
veee8's Avatar
Another great day with the National Speed Inc. Trans Am today. We won the Quick 8 shootout in Fayetteville NC. Another $500 in the pocket and a new best with 9.08 at 151! Left the line at 3500 rpm and 3.8psi of boost and ran 15psi through the run. It spun a touch on that pass with a 1.44 60ft. I ran several wheels up 1.3 60fts today, I will get pictures and video up tomorrow.
Oh and BTW Hoosier 325-50-15 Drag Radials rock the house!
Old Apr 19, 2009 | 06:06 AM
  #109
98Camarod's Avatar
Congrats on that! Lets see some vids!
Old Apr 19, 2009 | 09:55 PM
  #110
camarols1's Avatar
Amazing results with only 15psi, AWESOME !!!!
Wheels up launches are icing on the cake, congrats!
Old Apr 20, 2009 | 06:52 AM
  #111
Fireball's Avatar
sounds like its coming together...
now crank the boost up you sissy
Old Apr 20, 2009 | 08:37 AM
  #112
veee8's Avatar
LOL!!! I wanted to keep it all together for Pinks All Out Charlotte this coming weekend, after that we are cranking the boost up!
Here is a couple of vids and pics.
We didn't get the video of the second pass where it carried the front tires a long way, but hopefully it will turn up. Ran a 5.83 at 123 in the 1/8th that day too.
Old Apr 20, 2009 | 08:41 AM
  #113
Fireball's Avatar
Man I sure hope the changes I made the last 2 weeks pay off in the early numbers...you're running almost the same 1/8 mile time as I did 2 wks ago with 13 less mph
Old Apr 20, 2009 | 08:50 AM
  #114
longrange4u's Avatar
Made 4 passes today, track was hooking well. Best pass came with 2 step at 4500 rpm, left at around 8 psi.
60 ft. 1.51
1/8th 6.25
1/8th 120 mph
1/4 9.50
1/4 150.05 mph
It would dead hook, and then hazed the tires on this pass through first gear.
I have stock shocks and springs on the car, and I feel that is the fix for that. I will order a set of double adjustable AFCO's tomorrow.
Boost was set on 17 psi on this pass, and it felt awesome. This was a great baseline test, and we are planning whittling the 60 ft. down from here. The car ran perfect, with no issues.
Videos will be uploaded soon, I am too tired tonight. Not bad for a street car, huh?
Nice!! I think you have more in it!! You ran a .07 faster 1/8th then me... and identical 60'... you have the bigger frame turbo and a front mount vs: my rearmount PT88... I really think you got more in her!
Old Apr 20, 2009 | 08:53 AM
  #115
Hahhaah I see you are already down to 9.0!! Never mind my post!! I shoulda kept reading! See.. I said you have alot more in her!! Cant wait to run mine again! We have made a few "minor" changes...
Old Apr 20, 2009 | 09:19 AM
  #116
veee8's Avatar
This is with the 3.0 gearing. This PTC converter has been awesome.
Old Apr 20, 2009 | 10:02 AM
  #117
Fireball's Avatar
it'll be interesting to see what happens when you crank up the power level (boost)
Old Apr 20, 2009 | 10:26 AM
  #118
usenterprise's Avatar
saw your car at fayetteville saturday. great runs, way to take out the big boys. congrads.
Old Apr 20, 2009 | 10:35 AM
  #119
veee8's Avatar
When Dusty specced the converter, it was for the 3.0 gear, T-brake and 18-20 psi of boost. He said that 3.0 gear really puts a load on the converter, so it a pretty tight setup, 45* stator.
Thanks man.
Old Apr 20, 2009 | 06:54 PM
  #120
waterbug1999's Avatar
Man... I just read thru this thread and it rocks, nice set up.
