turbo setup(so far) andy suggestions
Old Apr 2, 2009 | 11:27 AM
bowtieguy04's Avatar
since im probally only going to run 5-9 psi can i use my msd boost a pump with my stock pump and be fine for now then when i want more power nswap the in tank out
Old Apr 5, 2009 | 10:15 PM
so thats it nothing else no sensors or lines or other random but usefull bull crap i forgot to put in?
Old Apr 5, 2009 | 11:32 PM
thumpstick's Avatar
You may need a threaded IAT sensor with a bung for your intake so it doesn't pop out when the you start making boost. You will also need all of the necessary lines and fittings for the oil feed/drain, and the turbo coolant lines. You will also need an oil scavenging pump if you mount the turbo low. also make sure that you get an aluminum weld on bung for the oil pan for the oil drain.
good luck,
-John
Old Apr 6, 2009 | 09:07 PM
where can i get a bung for the oil return? what size should the hose for the return line be.my turbo is mounted 14" above the return so i dont need a pump. i think my iat sensor is intagrated in to my maf thats what is says in the manual for the 2005 and up silverado's.
Old Apr 6, 2009 | 09:27 PM
thumpstick's Avatar
-10 braided line is what I have used in the past. Jeg's carries them along with braided line a fittings if you need them too.
bungs:
http://www.jegs.com/p/JEGS/752742/10002/-1
Old Apr 8, 2009 | 08:35 AM
can i take the small stock fittings out of my water pump and tap it for npt or an fittings the only reason i ask is i made everything fit and for got about my water pump. and it is too close to my manifold so i want to tap it for a 90 degree elbow so i can hook my hoses up for my heater. or is there a electric water pump that doesnt cost 400 -600 dollars for ls1's?
Old Apr 8, 2009 | 11:19 AM
so i have decided to take a 1/2 npt to -10 an 90 degree elbow and tap the water pump for this and run braided hose to my heater fittings on the fire wall. and i may do that for the second fitting too but with bigger fittings
Old Apr 14, 2009 | 11:25 AM
where should i get my push rods? should i change my springs if im running low boost?
