AIS meth kit question
Old Mar 23, 2009 | 09:19 AM
BOTTLE ROCKET's Avatar
Default AIS meth kit question
I purchased a AIS single stage meth injection kit, and wanted to get the activation set up close before I went to the dyno, since the pump is mounted in the fender, where it's a LITTLE tough to get to to make small adjustments while on a dyno
I want to set the system to activate at around 5psi. It comes factory set to activate at 10psi (I'm not planning to even run that much ) and the rep told me to turn it clockwise approx. 1 1/2 turns should put me around 5psi
I'd like to try and get a little closer from some tips from someone that has made some adjustments. I tried to find a "pressure" pump (not vacuum pump) that I could borrow/rent from an auto parts store, so I could be more accurate, but couldn't find anything
Anyone made adjustments to theirs that can give me info?
Old Mar 23, 2009 | 10:02 PM
Jimmy P's Avatar
I find it odd that it is set to activate at 10psi. Seems real high.
I would just do what the rep told you and turn it 1 1/2 turns clockwise, then adjust it once the car is on the dyno.
Old Mar 24, 2009 | 12:48 AM
SilverSS's Avatar
Mine came on at around 7 psi with the factory setting. Aren't you supposed to turn it counter-clockwise to lower the activation point?
Old Mar 24, 2009 | 06:15 AM
Not sure if it was clockwise or counterclockwise (from memory) but I did it while reading it straight from the book, so I should be correct.
"I find it odd that it is set to activate at 10psi. Seems real high.
I would just do what the rep told you and turn it 1 1/2 turns clockwise, then adjust it once the car is on the dyno."
That what it says in the manual. When I ordered it, the tech told me they would set everything up, jet sizes and boost activation, according to what I was going to run, but I guess that didn't happen.
I set based on what he said, but in fairness, he didn't REALLY sound like he was that sure of where it should be. He told me to buy a MAP tester so I could pump it to a certain psi and test it. Even if I could find one, it seem like a lot of $$ just to use for two mins.
Because of where I mounted it (in the fender well behind the front tire on a C-5) it will be impossible to adjust while on the dyno. That's the drawback of mounting it there, but also why I would like to get it preset
