When do you start building boost?
Chris
any FI motor can build boost instantly, or have "lag"
its all in the combination.
Had a friend with a D1 procharger on a stock mustang. would start at 1 lb and climb to redline and made 13psi total. But the boost took the whoooole band to build.
Other friend had a 91mm on a stock trans am.........STARTED making boost at 4,000 and peaked at 5 psi at 6,500. HORRIBLE lag.
both had the wrong setup, both wouldnt listen, BOTH were slow
Context one: Six speeds
a. Imagine idling next to a police officer at a stoplight and the officer is dying to give you at ticket. IE: you're behaving. The light changes and you slowly let out the clutch so you're not doing a sidestep of the clutch pedal at 6,000RPM. As your car begins to move, to your relief, the cop quickly turns right and takes off, having seen a donut shop with an empty parking space. You look at your boost gauge and Tach and stomp the gas pedal. At what RPM did it go into boost?
b. You're on the freeway, no one close either in front or behind. You downshift to 4th and slow down to 45mph and hold the RPM steady at that MPH. You look at the Boost gauge and Tach and stomp the gas. At what RPM did it go into boost?
Context 2: Automatics
a. No foot breaking. Just idling.... then, watching the Boost and Tach, stomp the gas. At what RPM did it go into boost?
b. Of course, because auto's downshift on a rolling stomp, I don't even think this one is worth noting. It's going into boost right away.
My M6 with 26" tall Nitto DR's and 4.10 gears is well into boost at 3K. I really need someone in the car to watch the gauges or get some kind of data logging because I don't want to even look at anything but the road when my car starts flying.
Chad
so i CAN make the statement that off idle, i can floor it and before you you can think about the word boost its on ten pounds, and hooked. (not directed at you)
but yes your right, 9 out of 10 cars cant take full boost at anything below3 or its a smoke show
running around town trying to find the dyno that will give me and my buddies some pretty sheets to go bragging about.
ALL i care about is beating the person next to me.
so ya my STOCK short block f 11 317 headed turbo motor is the "amazing" setup im talking about. BUT you have no idea what Wieght ,Gear ratio, Suspension, Transmission ,Shift points, and Converter im runnig as ALL that matters.
Just ask the guys with the 890 rwhp cobras in the KOTS compitition this last month in the newest mustang magazines that ran....12'S through the quarter!!!!!!!! LOL
OH sorry
What I do know is you have a stock shortblock setup so youre not running much more than 10psi.Unless you ran a setup that would be rediculously stupid to drive on the street, you're not going to make much of anything in the way of boost before 2500rpms.You have a centri blower car,ie making max boost at near redline.
cant answer because i have a 3600 vig, so cant tell you how much boost i make at 1500 or 200 rpms, like those numbers matter anyway.
so YES i make boost instantly, and im not the only one. Theres Plenty of people out there that do.
And yes your converter and gears DEFINATLY matter as to how and when boost comes in, timing and AFR also matter on the ramp speed.
your right though, not much more then ten psi. by tonight ill be on 14 but thats only good for what 80more hp if im lucky lol.
LOL i meant at idle when i stomp it it flashes my 3600 converter and im on full boost, to me thats "instant" i didnt mean at 1000 rpm i can make full boost or any for that matter LOL
