wanting turbo set up
Old Mar 26, 2009 | 12:24 AM
chevyforlife's Avatar
Default wanting turbo set up
i want to put a turbo on my 2000 camaro i have been looking at stuff for awhile now just dont know whats best for the price im kinda on a budget so if any one could help me out i would really appreciate it im wanting to do single front mount turbo with an intercooler
Old Mar 26, 2009 | 03:18 AM
TurboZ28408's Avatar
i have my used kit for sale. check my threads !!
Old Mar 26, 2009 | 04:37 PM
theblur98ss's Avatar
how much are you looking to spend and how much power do you want to make?
Old Mar 26, 2009 | 06:28 PM
99CAMMEDSS's Avatar
I bought one from josh at Kentucky Turbo and Performance, its pretty much the cheapest new f-body turbo kit you can get, and in my opinion and most others it is a really great kit.
Old Mar 26, 2009 | 10:22 PM
WS6HUMMER's Avatar
I like mine, got a great deal on it
Old Mar 27, 2009 | 08:32 AM
Y2K WS6's Avatar
cheaper isn't always better.
Old Mar 27, 2009 | 08:51 AM
Steve Burger's Avatar
LS1TECH Sponsor
Cheap and turbo don't go well in the same sentance. What is your budget?
Old Mar 27, 2009 | 08:54 AM
JAX04's Avatar
build your own setup. much cheaper. i bet when im done with mine i only have 2000.00 wrapped up in the install. 400 for a tune. and another 400 or so on tranny upgrades. done deal. 2800.00
Old Mar 27, 2009 | 12:02 PM
chevyz2801's Avatar
pm sent
Old Mar 27, 2009 | 12:18 PM
Sluggish's Avatar
It also isn't always bad when referring to KYTP prices and setups. I am very happy with my setup.
Old Mar 27, 2009 | 12:31 PM
WS6HUMMER's Avatar
I estimate that I have about 4500.00 in mine, cheap and turbo really dosent go together lol.
Old Mar 27, 2009 | 01:35 PM
JAX04's Avatar
what kind of turbo do you have? i have a master power t70, 60lb injectors, fuel pump?, b&m trans cooler. and i did all the work myself. bov, 38mm wastegate, and a magnaflow that will go after turbo. i just dont care about leaving that .10 or two on the table. i hate that sound. im only outsourcing the welding of the charge pipes. 400$. so i dont know waht you have in your. but thats a fairly cheap kit. and its realiable. for 4500 id have a built tranny
Old Mar 27, 2009 | 01:37 PM
JAX04's Avatar
oh, there you go, your turbo is about 1000 dollars more then mine. i know i have a good realiable entry level system. its proven.
Old Mar 27, 2009 | 09:03 PM
WS6HUMMER's Avatar
I have an S trim 76mm .96 AR Garrett that was part of an HP Mustang kit that I bought used from a friend (under 1000.00). I have a cheep BOV I bought for 50.00, a 50mm JGS wastegate (new but second hand), Seimens DEKA 57# injectors that were free but were low impedance so I had to buy a driver. For a fuel pump I just have a Racetronix kit for now. I welded everything myself, built it out of 304 stainless on the hot side and aluminum on the cold side. My intercooler cost me 100.00, I got it off a friend that bought it and it was too big for his car. I have a 4" dynomax race muffler and built the rest of the exhaust out of 304 stainless also. I bought a BMR turbo K-member so I could fit the 4" down pipe and Keep my A/C. I did everything myself, even bought a 75.00 used Weldcraft TIG torch off ebay for the build but bought a new welder halfway through the build with high frequency so I could weld aluminum. What really ended up costing me were all the little things that kept adding up, it seemed like every 2 weeks I was spending 450.00 on mandrel bends or flanges or something.
Old Mar 27, 2009 | 09:40 PM
98Camarod's Avatar
Don't forget about the boost referenced regulator
I have probably 2500-3000 in my setup. I Spent more like 4000 or so, but I sold alot of the items that were on my car, exhaust, nitrous, fans, radiator, tires, lid, maf, bunch of little things that added up just like all the little things that added up to 4k. I also bought a turbo that was too big for 500 and sold it for 950, so that helped out too.
Old Mar 27, 2009 | 09:43 PM
WS6HUMMER's Avatar
LOL, yeah I havent even bought that yet, & man do I need to.
Old Mar 27, 2009 | 10:13 PM
98Camarod's Avatar
I'm going to put on a hotwire kit tomorrow, so hopefully I'll be dropping my pressure on the regulator.
Sent you a pm Hummer
Old Mar 27, 2009 | 10:15 PM
VENGEANCE's Avatar
unfortunately cheap and turbo dont go together. I spent probably 33% more than expected on mine.
you can do budget for way cheaper, but it would help knowing your goals.
Old Mar 27, 2009 | 10:50 PM
elias_799's Avatar
properly turbocharging an ls1 will cost you quite a bit of money. and by properly turbocharging i mean lowering the compression, and at least changing the pistons and rods. and lots more stuff like high volume oil pump, bigger fuel pump, injectors... and the list goes on.
Old Mar 27, 2009 | 11:03 PM
LS1Silverado05's Avatar
Though I agree...sooner or later you have to draw a line and say..OK...this is my starting point...and as things break or fail you replace them or beef them up. I mean..one thing leads to another, and another, and another, and another...I have yet to ever see the "End" of a build.
